Thread: Wiring diagram for capacitor? PLEASE help! |
Silver Member Username: Phuktupbasshead
Phoenix,
Arizona
United State...
Post Number: 392 Registered: May-05
| Posted on Saturday, January 21, 2006 - 08:53 pm: |
I have an SPL capacitor, but the wiring diagram and instructions aren't consistent. They contradict each other. I lost the charging bulb. Also, the instructions are written in broken english. Can someone please help me hook this up right? Right now the amp and cap is hooked up to a ground. All I need to know is: do I hook up the cap and amp BOTH to the battery? or do i hook up the amp to the cap THEN just the cap to the battery? Thanks for reading. Please help. |
Silver Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 871 Registered: Feb-05
| Posted on Saturday, January 21, 2006 - 09:11 pm: |
hook the power wire from the battery to the cap, then from the cap to the amp |
Stockbridge,
GA
Post Number: 872 Registered: Feb-05
| Posted on Saturday, January 21, 2006 - 09:14 pm: |
http://www.rockfordfosgate.com/scripts/rightnow.cfg/php.exe/enduser/std_adp.php? p_sid=BT1TEc-h&p_lva=&p_faqid=50&p_created=952039877&p_sp=cF9ncmlkc29ydD0mcF9yb3 dfY250PTEwJnBfc2VhcmNoX3RleHQ9JnBfc2VhcmNoX3R5cGU9MyZwX3Byb2RfbHZsMT0yMiZwX3Byb2 RfbHZsMj0zOSZwX2NhdF9sdmwxPX5hbnl_JnBfc29ydF9ieT1kZmx0JnBfcGFnZT0x&p_li= |
