Home > Message Board > Car Audio > Amplifiers > Archive through January 28, 2006 > Amp on Ebay
Author Thread: Amp on Ebay
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 4442
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D5857347102%26&sspagename= STRK%3AMESE%3AIT%26
Item number: 5857347102
Username: James1115
Wilton, Ct
Post Number: 4591
hooked you up chaucey!
Huntsville, Alabama
U.S.
Post Number: 4444
Thanks, for gettin the ball rollin
Username: Fandim
Reno, Nevada
United State...
Post Number: 594
yay I'm the high bidder.. hurry up and end, auction!
Huntsville, Alabama
U.S.
Post Number: 4471
bump
Los Angeles, CA
Post Number: 1929
i feel like bidding on that amp. lol. hahahahahahaha. that stupid azz gave you a negative feedback. what a loser. he gave you a negative just because you gave him a negative? stupid idiot is lame.
Huntsville, Alabama
U.S.
Post Number: 4474
yep, he never shipped my cd
Los Angeles, CA
Post Number: 1932
oh yea you can buy cds from ebay huh? why didn't i think of that. i bet they are a lot cheaper too. i am gonna start shopping for cds right now. i need to get lil john, 50 cent, nelly, and xibit. they all have good bass. i found out the original cds have better bass then downloaded songs.
Huntsville, Alabama
U.S.
Post Number: 4476
ebay has anything and everything u could think of
Los Angeles, CA
Post Number: 1936
ebay don't have girls. lol. you can't get a fine girl on ebay.
Username: Fandim
Reno, Nevada
United State...
Post Number: 598
Yes you can.
Huntsville, Alabama
U.S.
Post Number: 4486
new high bidder
Los Angeles, CA
Post Number: 1945
what do mean seth? how lol.
Los Angeles, CA
Post Number: 1946
hey chauncey i might buy the arsenals. i emailed them and this is what he said.
Thank you for your email. As most of our customers will tell you,
I rate
our subwoofers very conservatively. I never want people to be unhappy
with
their setup and I want our subwoofers to last for a very long time.
There will
undoubtedly be many people using 1000 watts on the Arsenal subwoofers.
If you
are using the amplifier power for headroom and you watch your gains,
you will
probably never have a problem. They can handle a lot of power. I just
like to
recommend completely bulletproof power ratings. There are subwoofers
using
similar sized voice coils from other manufacturers that list power
handling
MUCH higher than we do, if that gives you any ideas.
Huntsville, Alabama
U.S.
Post Number: 4496
go 4 it. I would like 2 no how they perform, its ok to be a gunnia pig if its a great product
Username: Tdbdadrummer
Wellsburg, WV
Post Number: 1120
You know Chad, I've been trying to pump that information out of the other Chad for days now lol.
All I've gotten is that he doesn't suggest DOUBLING the power as Team Toxic Bass suggested. I'm glad to hear that though (I have Assassins), since I thought the subs just weren't all THAT loud (louder than Volfs), but I think it's because 400W RMS isn't enough...
Los Angeles, CA
Post Number: 1948
i am really tempted to. but i heard that they don't sound to good at higher frequencies. at least the avalanches didn't. also if i do buy these i figured i could sell my type xs for $100 each.
i am also tempted to get a pair of re sx. or maybe i should just save up and get the tis or the idmax like i originally planned.
Wellsburg, WV
Post Number: 1125
I posted something similar to this on another thread...but...
The Assassins sound good low, but the highs needed a bit of tweaking. I'm running them sealed, so I just set the subsonic filter to about 80Hz. I don't know exactly what it did, but the highs started playing a lot louder, while still maintaining the deep lows.
Username: Pelona
Post Number: 116
80hz is way too high for a subsonic filter
Username: James1115
Wilton, Ct
Post Number: 4613
are you sure you didnt set our LPF to 80hz tyler?
Wellsburg, WV
Post Number: 1137
No, I'm sure it was the subsonic...Wait lol...I set the subsonic, but I think I meant to set the LPF.
I need to go switch that up later. But yea, my LPF will be set to 80Hz. That's what Isaac set his A8000T to when he was testing, and it sounded good.
Huntsville, Alabama
U.S.
Post Number: 4534
Los Angeles, CA
Post Number: 1969
its not too late yet chauncey. give it to your bro. for the love of god man give it to your bro. please.
Huntsville, Alabama
U.S.
Post Number: 4617
Los Angeles, CA
Post Number: 2052
Description: Class D Monoblock Subwoofer Amplifier
Patented Technology: High-Damping Class D Circuit with discrete control circuitry (U.S. Patent #6,441,685)
Differential-Balanced Input Topology: 1 pair of inputs
On-board Crossover: Fully-variable (40-200 Hz), selectable-slope (12 or 24 dB per octave) LP
Preamp Output: 2-channel (independent active filter, parallel with amp filter or pass through)
Bass EQ: Single-band parametric with variable boost up to +15dB and Remote Bass Option
Infrasonic Filter: Fully-variable 24dB/octave from 15-60 Hz
Signal-Sensing Turn-On: Permits operation without remote lead
Dual mono speaker output connections: Accept up to 8 AWG wire
+12V and Ground connections: Accept up to 4 AWG wire
Rated Power: 500 W RMS @ 1.5 ohm - 4 ohm (11V-14.5V)
THD at Rated Power: <0.05% @ 4 ohm
S/N Ratio: >95dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
Frequency Response: 5 Hz - 500 Hz (+0, -1dB)
Damping Factor: >500 @ 4 ohm / 50 Hz
>250 @ 2 ohm / 50 Hz
Input Range: Switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions (L x W x H): 13.40 in. x 9.25 in. x 2.36 in.
340 mm x 235 mm x 60 mm
Huntsville, Alabama
U.S.
Post Number: 4645
^^THANX CHAD!!!
Username: Insearchofbass
Post Number: 4362
now im the high bidder
Post Number: 4363
sorry had to retract
Huntsville, Alabama
U.S.
Post Number: 4646
thats fine good luck, if u win i will charge u acutal shipping
Huntsville, Alabama
U.S.
Post Number: 4648
u cancelled ur bid???
Los Angeles, CA
Post Number: 2076
10hours left on this fine amp.
Username: Fandim
Reno, Nevada
United State...
Post Number: 624
Heh.. Wonder if anyone else will bid.. I contemplated upping my bid a bit more.. but since the person I'm bidding against has only one other purchase on Ebay, and it was also through chauncey.. gonna find a different one to buy.
Huntsville, Alabama
U.S.
Post Number: 4681
I guess its over
Username: Project6
Post Number: 4915
Who won? Anyone on this board?
Huntsville, Alabama
U.S.
Post Number: 4688
I dont think so, He's from Columbia, SC, like baseball1187 though
Home > Message Board > Car Audio > Amplifiers > Archive through January 28, 2006 > Amp on Ebay [ « Previous ] [ Next » ]
