Thread: I need an amp |
New member Username: Logan_17
Post Number: 1 Registered: Jan-06
| Posted on Friday, January 20, 2006 - 10:20 pm: |
i need an amp for these subs Audiopipe 12 in. Subwoofer Features: 1600 Watts Power (PMPO) 800 Watts Power (RMS) Frequency Response: 23-1000Hz Sensitivity: 96dB Air Cushion Foam Surround One Piece Metal Cone Candy Red Die-Cast Aluminum Basket 2.5 in. 2 Ohms 4-Layer Black Aluminum Dual Voice Coil Nomex Spider 120 oz. Magnet i have two of them....does anyone know what kind of amp i should get and where i could find it. Im on a budget so it cant cost that much. |
Gold Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 4425 Registered: Jul-05
| Posted on Friday, January 20, 2006 - 10:27 pm: |
AudioBahn A2200HCT |
New member Username: Logan_tille
| Posted on Wednesday, January 25, 2006 - 06:34 pm: |
will this work, GM-4CLD Audiopipe Class D Features Fully 1 Ohm Stable Operation Variable Low Pass Electronic Crossover Remote Subwoofer Level Controller Phaser Function High Efficiency PWM Power Supply 3-Way Protection Circuitry Variable SubSonic Filter Distortion: Less than 0.5% THD Signal to Noise Ratio: 96dB RCA Input Sensitivity: 0.2 to 5 V Input Impedance: >20KOhm Low Pass Filter: 40 to 250 Hz/24 dB Oct. Subsonic Filter: Oct 10 to 50 Hz/24 dB Oct. Frequency Response: 10 to 300 Hz. Output Power (RMS): 400 Watts @ 4 Ohms 700 Watts @ 2 Ohms 1200 Watts @ 1 Ohm Single Channel Operation if i wire the subs in series what will the ohm load be? and will they have more or less power than running on a 2 channel amp? |
Bronze Member Username: Do_em_dirty816
Kansas City,
MO
Post Number: 47 Registered: Jan-06
| Posted on Wednesday, January 25, 2006 - 09:17 pm: |
if youre on a budget maybe the hifonics bx1500d... but i would only choose that amp IF you're on a budget like a $150 - $200 budget. |
Post Number: 2 Registered: Jan-06
| Posted on Friday, January 27, 2006 - 04:04 pm: |
ok so if i got that amp how should i wire my subs to it. |
Silver Member Username: N2audio
Lawrence,
Ks
Post Number: 449 Registered: Mar-04
| Posted on Friday, January 27, 2006 - 04:32 pm: |
Post Number: 3 Registered: Jan-06
| Posted on Saturday, January 28, 2006 - 01:07 am: |
will that work the same for 2 ohm subs? or doesnt it madder what ohm they are? |
Post Number: 4 Registered: Jan-06
| Posted on Saturday, January 28, 2006 - 06:15 pm: |
i wired both of my subs to a 2ohm load, but now they soud a little different then before, and they dont push out as far as they used to. since i wired them to a 2 ohm load does that mean they are each 1 ohm or are the both 2? |
Bronze Member Username: Goatin
Post Number: 78 Registered: Jan-06
| Posted on Saturday, January 28, 2006 - 06:21 pm: |
You could buy my amp I have a thread (NEW amp for sale)for more info |
Silver Member Username: Cadillacdb
Houston ,
TX
Post Number: 426 Registered: Aug-05
| Posted on Sunday, January 29, 2006 - 12:07 am: |
To answer your Question about if ohms matters, yes it matters a whole lot because what ever ohms load you have your Subs wired for is the load your amp is gonna see an put out its rated power for that impedance, also you dont wanna put an ohms load that the amp isnt capable of handling Wiring Wizard http://www.rockfordfosgate.com/rftech/wiringwizard.asp |
Houston ,
TX
Post Number: 427 Registered: Aug-05
| Posted on Sunday, January 29, 2006 - 12:13 am: |
Logan... Also, if your Subs are 2ohms DVC an you wire them the way Optidriven Is showing you to, then you would have a 0.5 ohms load not a 1 ohm load |
Houston ,
TX
Post Number: 428 Registered: Aug-05
| Posted on Sunday, January 29, 2006 - 12:16 am: |
if your trying to wire two 2ohms DVC subs together then your options are 2 ohms, 0.5 ohms or 8 ohms ..... |
Post Number: 5 Registered: Jan-06
| Posted on Sunday, January 29, 2006 - 02:59 pm: |
lets say i got a HiFonics BX1500D its 1000 watts rms at 2 ohm. if i wired my subs to it would they both be getting 1000 watts or would the be getting 500? |
Post Number: 9 Registered: Jan-06
| Posted on Tuesday, January 31, 2006 - 08:55 pm: |
do you think that amp would underpower them to much?
Post Number: 10 Registered: Jan-06
| Posted on Tuesday, January 31, 2006 - 10:06 pm: |
also i was thinking about getting 2 audiobahn A8000t's. If i was to hook two of them up in my trunk could i like split the power cable into and run both amps off that one cable, And could i do the same with the ground? |
Lawrence,
Ks
Post Number: 493 Registered: Mar-04
| Posted on Wednesday, February 01, 2006 - 10:40 am: |
with the 1500d at 2 ohms each sub would get about 400w (it's a little over-rated) a pair of 8000t's would work well for two dual 2's, but you'd need 2 ga or 1/0 ga power/ground wire split to a 4 ga (8 if it's short) for each amp. You might consider this http://cgi.ebay.com/ebaymotors/Lanzar-OPTI-2000D-2000-D-Mono-Block-Digital-Ampli fier_W0QQcmdZViewItemQQcategoryZ38638QQitemZ8034523056QQrdZ1QQsspagenameZWDVW 1900w at 1/2 ohm. |
New member Username: Bobbybig
Post Number: 5 Registered: Feb-06
| Posted on Sunday, February 05, 2006 - 01:55 pm: |
hi. i have recently bought my first car and have no clue about car audio so pls be patient with me. i have a jvc head unit (4x50watt?) 2 alpine 13cm speakers 150 watt and a kenwood sub 12" 600watt (peak). Can you pls help me, do i need an amp if so what one and its on a tight budget thanks guys. |
| Posted on Monday, February 06, 2006 - 05:53 pm: |
what ohm load is your sub? |
Bronze Member Username: Logan_tille
Post Number: 12 Registered: Jan-06
| Posted on Monday, February 06, 2006 - 05:59 pm: |
now im thinking about this amp: Digital LCD Display (Voltage, Temperature & Output Level) Platinum Plated Connections Quiet Fan Cooling System Top Loaded Power & Protection LED?s Thermal / Short / Overload Protection Circuitry 0-18 dB Variable Bass Boost 40-250Hz Variable High Pass Crossover 40-250Hz Variable Low Pass Crossover Remote Bass Control THD @ 4 0hm <0.05% THD @ 2 0hm <0.1% THD @ 1 0hm <1.0% S/N Ratio: >90dB Channel Separation: 60dB Frequency Response: 20-20kHz Input Voltage Range: 200mV - 8V Input Impedance: 10k Ohms 24dB Subsonic Filter (HK-401SX only) 1 x 500W RMS @ 4 Ohm Mono 1 x 650W RMS @ 2 Ohm Mono 1 x 1200W RMS @ 1 Ohm Mono 1 x 1800W RMS @ 0.5 Ohm Mono Dimensions (H x W x L): 2.7" x 12.4" x 10.6" would this amp work for my subs? |
| Posted on Wednesday, February 08, 2006 - 01:53 pm: |
haha....your system sucks.....hahaha |
Post Number: 6 Registered: Feb-06
| Posted on Thursday, February 09, 2006 - 05:20 pm: |
4 ohm is my sub |
| Posted on Friday, February 10, 2006 - 05:51 pm: |
do you know the rms watts?.....im guessing around 200....so im gonna say that this amp will be pretty good.....http://www.ikesound.com/product-product_id/2452 |
| Posted on Friday, February 10, 2006 - 05:52 pm: |
ops i mean around 300 |
