Home > Message Board > Car Audio > Amplifiers > Archive through January 28, 2006 > Amplifiers the eternal ?
Author Thread: Amplifiers the eternal ?
Username: Jp1981
Dallas , Tx
Usa
I recentley bought two MTX 8500 series subwoofers they are about 900-1100 watts each. I need to know how to hook up two mono amplifiers, how do i get power to them and how do they hook up to the head unit (remote wire,output and input wires) please don't spare any details. Or what kind of 2 channel amp is out there that handle both the speakers?
Username: Brynm
Prince Albert, SK
Post Number: 164
what's your budgetand what are the voice coil configs?
Username: Jp1981
Dallas , Tx
Usa
3" high temp voice coils 428°F Voice Coil Wire Temp Rating. And my budget can get can go eaither way but the less money i spend the better.
thanks bro.
Username: N2audio
Lawrence, Ks
Post Number: 373
http://www.bcae1.com/amplfier.htm
Username: N2audio
Lawrence, Ks
Post Number: 374
The 8500's are either dual 4 ohm coils or single. That's the info we need.
Also - the 10's and 12's are 500w rms, the 15's are 600w.
The most logical way to power them would be with one mono amp that's 1000-1200w at 1 or 2 ohms - depending on whether you have svc's or dvc's.
Username: Jp1981
Dallas , Tx
Usa
My 8500's are single coil.
Username: N2audio
Lawrence, Ks
Post Number: 388
you're looking for a mono amp around 1200w at 2 ohms.
Username: Insearchofbass
Post Number: 4354
my amp here is for sale
http://forum.ecoustics.com/bbs/messages/4/192406.html
Post Number: 4355
i had the 8000 mtx 10's trust me they handled more than the 400 rms each
Home > Message Board > Car Audio > Amplifiers > Archive through January 28, 2006 > Amplifiers the eternal ? [ « Previous ] [ Next » ]
