Thread: Need help asap..installing this very min |
Bronze Member Username: Zulkir
U.S.A.
Post Number: 52 Registered: Dec-05
| Posted on Friday, January 20, 2006 - 12:28 pm: |
how bad is it to rin the power wire with the rca cables? i got the rca cabls and the remore wires on the door frame adn woudl it be okay to run the power wire on the out side of that under the carpet nexto to rca cabls.when it gets to the back part of the car the power cabls and rca cabls will be coming out of the same spot. |
Gold Member Username: Tjmutlow
Post Number: 1043 Registered: Sep-05
| Posted on Friday, January 20, 2006 - 03:08 pm: |
Best bet, run on opposite sides of car. |
Silver Member Username: Scubasteve
College Park,
MD
Post Number: 883 Registered: May-05
| Posted on Friday, January 20, 2006 - 03:12 pm: |
there's a lot of debate on this one. I've always ran them atleast a few feet apart. |
U.S.A.
Post Number: 53 Registered: Dec-05
| Posted on Saturday, January 21, 2006 - 12:04 am: |
crap i only have 17 ft of wire i cant run it on teh opp side of the car best i can do is mabe down the middle.the emf on the wire cant be that big..i dout it is comes out more then 1 1/2 inches in each direction of the wire. |
College Park,
MD
Post Number: 889 Registered: May-05
| Posted on Saturday, January 21, 2006 - 01:10 am: |
run the power wire on whatever side is easiest, remote and RCA's can go down the middle. |
Post Number: 1051 Registered: Sep-05
| Posted on Saturday, January 21, 2006 - 07:21 am: |
most 17ft rcas will work in most cars,what kind of car do you have. |
Gold Member Username: Carguy
Post Number: 5220 Registered: Nov-04
| Posted on Saturday, January 21, 2006 - 11:14 am: |
If you're going to do the install, do it right. If not, you'll get the annoying "alternator" noise. 17' of rca cable is plenty, even for a van. |
Bronze Member Username: Hnic_men
Post Number: 68 Registered: Oct-05
| Posted on Saturday, January 21, 2006 - 03:40 pm: |
Silver Member Username: Dustin3
Tigard,
Or
U.S.
Post Number: 310 Registered: Oct-05
| Posted on Saturday, January 21, 2006 - 08:50 pm: |
wut was that picture for? |
U.S.A.
Post Number: 54 Registered: Dec-05
| Posted on Saturday, January 21, 2006 - 09:01 pm: |
i am talking 17ft of power not rca cable adn i already tryed to run it on the opp side its way to short so its going to have to go down the middle some how adn ill be lucky if it will work then because of all the little room inbetween everything.unless i take it all back out and run teh rca cabls down the middle because they are alot smaller and the power wire on the side.
Silver Member Username: Phuktupbasshead
Phoenix,
Arizona
United State...
Post Number: 394 Registered: May-05
| Posted on Saturday, January 21, 2006 - 09:11 pm: |
different quick question (but Zulkir can benefit as well): what if, in the trunk, the power, ground, and speaker wires end up criss crossing over one another (basically touching)? Bad? no biggie? thanks, everyone. |
Post Number: 1068 Registered: Sep-05
| Posted on Sunday, January 22, 2006 - 07:52 am: |
run the power cable on the side whe it goes through the firewall.It should be long enough. |
Gold Member Username: Tdbdadrummer
Wellsburg,
WV
Post Number: 1145 Registered: Aug-05
| Posted on Sunday, January 22, 2006 - 11:13 am: |
Maybe...Buy a longer power wire? |
