Thread: JL Audio |
New member Username: Lowemotions
Post Number: 1 Registered: Jan-06
| Posted on Thursday, January 19, 2006 - 07:04 pm: |
I have a 12w7 and a 1000/1 JL amp. in a 95 Escort and the last time I went to a comp. I hit 162.9. I have 2 optimum jell batts. and a 1 farad cap. How can I get more out of my system. |
Silver Member Username: Pelona
Post Number: 104 Registered: Dec-05
| Posted on Thursday, January 19, 2006 - 07:11 pm: |
you did not hit 162.9 you liar. |
Gold Member Username: 54danny54
Betsy layne,
Kentucky..GO...
USA duh
Post Number: 1535 Registered: Nov-04
| Posted on Thursday, January 19, 2006 - 07:12 pm: |
first of all i doubt u hit 162.9 dB with a single 12W7 but to get more out of it...go ported if u havent already, screw around with box placment mess around with the tuning a little bit |
Post Number: 2 Registered: Jan-06
| Posted on Thursday, January 19, 2006 - 07:13 pm: |
my fault I hit 142.9.. i hit the wrong # sorry
Post Number: 3 Registered: Jan-06
| Posted on Thursday, January 19, 2006 - 07:15 pm: |
And the W7 is in the ported JL box they made for that sub |
Gold Member Username: Jonathan_f
GA
Post Number: 5451 Registered: May-04
| Posted on Thursday, January 19, 2006 - 07:28 pm: |
142.9 from a single 12" sub is very respectable, especially if it's a SQL application and on the new termlab. Not a lot more you can do while retaining musicality, aside from adding another sub and amp. |
Post Number: 6 Registered: Jan-06
| Posted on Thursday, January 19, 2006 - 07:40 pm: |
What do you think about the JL 13W7... what would that do for me? |
GA
Post Number: 5454 Registered: May-04
| Posted on Thursday, January 19, 2006 - 07:53 pm: |
Replacing your 12W7 with a 13W7 will get a little louder, but not the gain you would get from adding another 12W7. |
Silver Member Username: Fandim
Reno,
Nevada
United State...
Post Number: 587 Registered: Jun-05
| Posted on Friday, January 20, 2006 - 12:30 am: |
also, there is no prefab HO boxes for the 13w7 like your 12w7, so unless you're very good at box building, you'd actually lose a little bit. |
Post Number: 7 Registered: Jan-06
| Posted on Friday, January 20, 2006 - 01:58 am: |
would my 1000/1 run 2 12w7's |
Reno,
Nevada
United State...
Post Number: 590 Registered: Jun-05
| Posted on Friday, January 20, 2006 - 03:41 am: |
nearly perfect, Joe. |
Silver Member Username: Solacedagony
New Jersey
US
Post Number: 749 Registered: Oct-04
| Posted on Friday, January 20, 2006 - 10:29 am: |
If you're running your 12W7 w/ a 1000/1 now, why not get another 12W7 powered by another 1000/1? |
Gold Member Username: Tjmutlow
Post Number: 1038 Registered: Sep-05
| Posted on Friday, January 20, 2006 - 10:58 am: |
the JL is not an spl sub morre of a sql sub, and that comes from the mouth of the JL rep. |
Gold Member Username: James1115
Wilton,
Ct
Post Number: 4561 Registered: Dec-04
| Posted on Friday, January 20, 2006 - 12:24 pm: |
if you could add 1 more sub it wouldnt make that much of a difference if any. You are currently running 1-12 with 1000 watts, now if you add a second and give them 500 each you will be losing 3db's for cutting the power in half but adding 3db's for surface area of another sub. 142.9 is very loud for a everyday application if you want to go strict SPL thats one thing you can get much higher but if you want it to maintain decent SQ then you arnt going to get much higher unless you plan on dropping a good amount of money which you might be prepared to do I have no idea. NICE score man especially if it was legally judged on the new term lab |
Post Number: 8 Registered: Jan-06
| Posted on Friday, January 20, 2006 - 09:26 pm: |
thanks all, i will inform you on what i decide to do and let you know how it turns out. thanks again for the input |
GA
Post Number: 5469 Registered: May-04
| Posted on Friday, January 20, 2006 - 10:31 pm: |
"f you could add 1 more sub it wouldnt make that much of a difference if any. You are currently running 1-12 with 1000 watts, now if you add a second and give them 500 each you will be losing 3db's for cutting the power in half but adding 3db's for surface area of another sub." It's considered that doubling total power (not power to each individual driver) is what provides a 3db increase. Maintaining the same total power will keep you at that level, with the 3db benefit of added cone area. So it'd be a 3db gain. |
Wilton,
Ct
Post Number: 4593 Registered: Dec-04
| Posted on Saturday, January 21, 2006 - 01:47 am: |
either way not worth $500 |
Silver Member Username: Ucfsaxman
Oviedo/orlando,
Fl
Post Number: 539 Registered: May-05
| Posted on Saturday, January 21, 2006 - 04:23 pm: |
i always thinks it's funny when the W7 comes up and people say its a SQL sub. but bottom line those damn things get loud. maybe not for hardcore spl people and compared to these underground internet spl subs like RE and AA and whatever but for all tense and purposes the W7 is a loud sub. |
GA
Post Number: 5479 Registered: May-04
| Posted on Saturday, January 21, 2006 - 05:00 pm: |
W7 will hang with an XXX and Avalanche, though the 15" XXX and Ava will slightly surpass the 13W7. But, W7 sounds better IMO. |
Gold Member Username: Carguy
Post Number: 5221 Registered: Nov-04
| Posted on Saturday, January 21, 2006 - 06:44 pm: |
I 2nd that. I've bashed JL in the past, but after I got one and tested it, I was impressed. If you really want to compete with 15" XXX, then ask JL to build you a custom HO box for 13W7. You'll need a large van though. |
New member Username: Dumbbass
| Posted on Wednesday, January 25, 2006 - 10:48 pm: |
I have a 12w7 and i plan on putting in a civic si 04 Hatchback...is a jl audio amp 500/1 good enough? or should i go all out and get the jl 1000/1?Or go with a amp that puts out 600 watt RMS? please help me out there jl audio professionals?
New member Username: 04yellowgto
Tuscaloosa,
Alabama
| Posted on Thursday, January 26, 2006 - 02:21 am: |
What do people think of Digital Designs? I had a 3515, built my own box to specs and powered it by a hifonics 1500d. It was the loudest I'd ever heard, but then again, I've never been to any competitions. Any inputs? |
Gold Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 4687 Registered: Jul-05
| Posted on Thursday, January 26, 2006 - 02:57 am: |
I like DD subs quick guide http://pub14.ezboard.com/fcaraudiotalkfrm27.showMessage?topicID=27.topic |
Post Number: 4911 Registered: Dec-03
| Posted on Thursday, January 26, 2006 - 02:59 am: |
Nice |
| Posted on Thursday, January 26, 2006 - 03:32 am: |
Others might disagree, but I'd just with the 1000/1. Otherwise, look for an amp that's stable at 1.5 ohms. Most other amps will only show ratings at 1, 2, and 4 whether or not they're stable at something odd like 1.5 |
Huntsville,
Alabama
U.S.
Post Number: 4690 Registered: Jul-05
| Posted on Thursday, January 26, 2006 - 03:34 am: |
Bob u post a lot of nice stuff why not register |
