Thread: My battery marks 12.9v (with the engine off) is it good? |
Silver Member Username: Panamanian
Panama city Panama
Post Number: 183 Registered: Aug-05
| Posted on Thursday, January 19, 2006 - 11:43 am: |
my car battery shows in my multimeter 12.9v (with everything off, (including engine off). It's a sealed battery (PANASONIC), 550amp i think Is this good? normal? bad? gracias |
Gold Member Username: Carguy
Post Number: 5196 Registered: Nov-04
| Posted on Thursday, January 19, 2006 - 12:35 pm: |
That's good. Normal voltage is around 12.5v - 12.9v. If you get below 12v, then your battery is either not holding charge or not charging. |
Silver Member Username: Fandim
Reno,
Nevada
United State...
Post Number: 586 Registered: Jun-05
| Posted on Friday, January 20, 2006 - 12:24 am: |
hmmm....well, it's interested that it's at 12.9 volts.. this means that your alternator at idle wont charge your battery, since most alternators idle at 12.5 volts or so. Also, it could mean that dropping this battery to 12 volts would be like dropping a 12 volt battery to like 11.2 or so.. Might want to make sure it's a 12v battery. |
Panama city Panama
Post Number: 184 Registered: Aug-05
| Posted on Friday, January 20, 2006 - 12:40 pm: |
yes, it's 12V, while my car was parked it was showing 12.93 to be exact, and again, my engine was off, i remember two weeks ago that i checked my battery with only my engine ON and everything off and it was showing 13.7v Is this still wrong? or quite normal? |
