Thread: EQ Setting on Kenwood XXV-01D CD help!! |
New member Username: Thunder
England
Post Number: 1 Registered: Jan-06
| Posted on Wednesday, January 18, 2006 - 05:04 pm: |
Hi Guys, which frequency do I set for each band and at what Q Factor for the best sound quality? Band 1: 60/80/100/120/160/200 (Hz) Band 2: 250/315/400/500/630/800/1k (Hz) Band 3: 1.25/1.6/2/2.5/3.15/4 (khz) Band 4: 5/6.3/8/10/12.5/16 (khz) Q Factor: 0.25/0.50/1.00/2.00 for each band My current X-Over settings on the amp are Front HPF:80hz, Rear: not used & Sub LPF 80HZ. The X-Over on the Headunit is not used.
England
Post Number: 2 Registered: Jan-06
| Posted on Friday, January 20, 2006 - 04:44 pm: |
anyone? |
Bronze Member Username: Spkr589
Post Number: 13 Registered: Jan-06
| Posted on Monday, January 30, 2006 - 06:31 am: |
Yeah that is a difficlult thing to pinpoint. I have a excelon x589 with similar settings. Had if for a month and I am still plaing around with it. It would seem to me to be subjective to the listener. I know thats not much help but just keep fiddeling with it. It just takes time to tweek. Good luck  |
New member Username: Pulser
Post Number: 2 Registered: May-06
| Posted on Thursday, May 11, 2006 - 02:29 am: |
you need to set the EQ bands depending on what is too loud or too soft in the frequency response. i.e. if the female vocals are too harsh, set band 3 for 4kHz, Q=1, gain=-2 you really need to know what parts of the audio spectrum (frequency) are uneven, and set the EQ appropriately. EQ settings will be different for every car, and for every brand or model of speakers.
Bronze Member Username: Johammbass
Cork,
Cork
Ireland
Post Number: 66 Registered: May-06
| Posted on Monday, May 15, 2006 - 01:05 pm: |
RTA would help, but ears are the best to judge that |
