Home > Message Board > Car Audio > Amplifiers > Archive through December 11, 2003 > Sony amp, somethings wrong!
Author Thread: Sony amp, somethings wrong!
i have 2 12W3D4 running 8 ohm by the bridged 760w amp, it sounded great for about a week then one morning amp blew fuse and didnt work, subs made wierd noise when i turned it on but didnt work at all, please help
Your first problem...a sony amp. Sounds like you might have killed your amp. The problem was probably that you were running 8 ohm into 4ohm subs and ur amp overheated. I guess I assumed that u were running 320x2 at 8 ohms a piece. Anyway...ur amp sounds fried...it would be better to buy another than to get that sony pos checked out!
how do i hook that sony 760 watts amp into 4 ohms
marcus
this is my first time tring to put a system in my car and i dont understand how your amp can be 2 ohm or 4 ohm or even 8 ohm i read up there that you can blow you amp up can anyone help me out so i dont blow it up.
Home > Message Board > Car Audio > Amplifiers > Archive through December 11, 2003 > Sony amp, somethings wrong! [ « Previous ] [ Next » ]
