Thread: Whats the difference between ANL and AGU fuses?? |
Silver Member Username: Safa19
Post Number: 272 Registered: Apr-05
| Posted on Friday, January 13, 2006 - 05:33 pm: |
it seams that the agu only run up to 80amps and the anl go up to like 300amps, whats the difference? y wouldnt everyone just get anl? or is the way that agu made make it equal to the anl with a smaller amp rating? |
Silver Member Username: B101
Queen City,
NC
Post Number: 421 Registered: Sep-05
| Posted on Friday, January 13, 2006 - 07:43 pm: |
AGU are glass cylindrical shape. Normally low in amps, like u said 80. ANL is for more high current applications. I belive u can get a ANL fuse up to 600 amps. Its hard to find, but u may get it at a boat/marine store. I have a 200 amp ANL fuse, paid 5$ for it. |
Queen City,
NC
Post Number: 422 Registered: Sep-05
| Posted on Friday, January 13, 2006 - 07:44 pm: |
http://www.bcae1.com/fuses.htm There u go JOE |
