Thread: Frustrated, need help! |
New member Username: Wolfman1966
WEST MONROE ,
LOUISIANA
Post Number: 4 Registered: Jan-06
| Posted on Thursday, January 12, 2006 - 04:09 pm: |
Hey, I am installing a 350 watt amp and 2-10 inch subwoofers in the trunk of my 2004 Dodge Neon...I have almost everything done, except for one thing...the power cable. I can't find any way to penetrate the firewall, and I am afraid to drill cause I might hit something important...can ANYONE tell me where I can run the wire through.. any help is greatly appreciated |
Gold Member Username: Carguy
Post Number: 5174 Registered: Nov-04
| Posted on Thursday, January 12, 2006 - 04:31 pm: |
Open your hood and look at the fire wall. You will see some round black, rubberish plugs. Some of them will lead you into the car's cabin. Get a wire coat hanger and feed it through to see where it comes out. Not that hard. If for some odd chance none of them lead to the cabin, you can drill a hole near the bottom of the wall. Since every single car has electronic inside the dashboard, there WILL be holes, guaranteed. Sometimes, they're covered by the carpet. |
