Thread: HELP |
Silver Member Username: Mrdark
Post Number: 178 Registered: Dec-04
| Posted on Tuesday, January 10, 2006 - 10:39 pm: |
Okay, Ive got 2 PPI A300 and a MMATS D200HC. I want to know what size fuze at the battery seems logical, 100A? 150A? 200A? Each of the PPI A300 has an onboard 40A fuse, so will the battery fuse just see that as a single 40A draw or 80A draw? |
Silver Member Username: Tjmutlow
Post Number: 955 Registered: Sep-05
| Posted on Wednesday, January 11, 2006 - 04:49 am: |
100a |
Silver Member Username: Infinity_addict
Santa Rosa,
California
Post Number: 228 Registered: Jul-05
| Posted on Wednesday, January 11, 2006 - 02:41 pm: |
the fuse is to protect the wire, not the amp. your amp has it's own fuses to protect itself. so get whatever fuse matches yer power wire. |
Post Number: 180 Registered: Dec-04
| Posted on Saturday, January 14, 2006 - 12:53 am: |
thanks ty and infinity addict. so...0 ga wire can handle up to 200A, so I'll use a 200A fuse at the battery? I dunno...I'm in the process of upping my alt to a 200A ho alt. any others wanna throw in some advice/help? just what would yall do? 100A or 200A? |
