Thread: Fuses......kepp blowing? |
New member Username: Tbk
Post Number: 3 Registered: Jan-06
| Posted on Sunday, January 08, 2006 - 05:22 pm: |
well I recently hooked up my system and my fuse keeps blowing... the amp will power on for about 3 or 4 seconds then the fuse in the power cord blows... any idea why this happens? |
New member Username: Chevydriver
Mason,
OH
US
Post Number: 8 Registered: Nov-05
| Posted on Thursday, January 12, 2006 - 03:00 pm: |
Your fuse could be too small for the amp. You could try putting in a bigger fuse and see what happens. |
Gold Member Username: Carguy
Post Number: 5169 Registered: Nov-04
| Posted on Thursday, January 12, 2006 - 03:07 pm: |
What is the amp's model/brand and the fuse size? An amp shouldn't blow fuses without any load, regardless of the fuse size (within reason). |
Bronze Member Username: Pricey1985
Sydney,
NSW
Australia
Post Number: 26 Registered: Jul-05
| Posted on Wednesday, January 18, 2006 - 05:40 am: |
Hey, what size is the fuse you keep blowing. Above around 20-30amp u got a problem. Firstly is to double check the power wiring to make sure it is hooked up right and to see if it havnt say chaffed or something and its earthing out. I had this problem with my amp, I had wired it all up and it was working for about a week ok untill the amp blew up. From then the amp itself was just shorting the (+) and (-) somehow. I opened the amp up and found some MOStransistors not working and replaced them, when i hooked it up the blowing of the fuse was fixed but it still didnt work (must be another chip or something stuffed) anyway what i am saying is that the amp itself might be stuffed like mine. |
