Thread: Ipod into aux. input only playing through right speakers |
New member Username: Milkandmeat
Post Number: 1 Registered: Jan-06
| Posted on Saturday, January 07, 2006 - 09:21 pm: |
The Aux on this head unit (panasonic) is 2 plugs (red/white) just like the pre-outs and stuff. It works and sounds good, but it only plays through the right speakers. Checked the EQ and everything, and tried different songs but still happens. I made sure everything was plugged tight too. I used a cable with gold connectors i got from best buy for 10 dollars.... Any ideas what might be the problem? http://www.bestbuy.com/site/ol...85343
Post Number: 2 Registered: Jan-06
| Posted on Saturday, January 07, 2006 - 09:24 pm: |
http://www.bestbuy.com/site/olspage.jsp?skuId=7220777&type=product&id=1114639085 343 thats the cable im using
Post Number: 5 Registered: Jan-06
| Posted on Saturday, January 07, 2006 - 09:59 pm: |
so check it out....the red pluginto the red side of the aux worked, which is the right speaker side. the white side is what didn't work. so i plugged the red plug (from the ipod) into the white side of the aux input, and the left speakers came on. so, the problem must be a fucked up cable, correct? |
Silver Member Username: Tjmutlow
Post Number: 902 Registered: Sep-05
| Posted on Sunday, January 08, 2006 - 08:21 am: |
use a y adapter(2 female to 1 male into the side that works, if both sides work, then switch out the rcas. |
