Home > Message Board > Car Audio > Security Systems > Archive through March 15, 2006 > Need some help or advice on car audio...
Author Thread: Need some help or advice on car audio or security??
Username: Stnebrdgecustom
Hazel Crest, IL
If you live close, get help in person!! Email all your questions and problems to me. just call me the problem solver. I just want to help good people!
kev20
I could use help. I have a 99 Saturn Coupe. I purchased a remote starter from Bulldog Security and I need to bypass the factory installed alarm system. This link has a diagram, but I cannot locate the security module to even start the bypass.
http://bulldogsecurity.com then click on wiring diagrams and then choose the vehicle type.
In fact, I am also having difficulty finding the lock/unlock wires-I think I tested all the wires in the kick panel. I have everything else hooked-up and the remote start works, but only when the car is unlocked. Any tips?????
Just got a viper xpress(?) alarm. Can someone help me decrease the sensor sensitivity. It goes off all the time!!!
My neighbors would really appreciate your help!
I bought a sony cdx-m800 in 2004 an ive just got a new car when i changed the cd player over it wanted the security code i installed when i first had it. ive tried what i thought it was and it says code error is there anyway to overide the code system?
kev20
Chris, I may be interested in your personal help since I live in Chicago. Please respond to my issue above. Thanks.
Username: Fnfreek
hey i have an alpine 8028 security system in my truck, it started going off and i had lost the keys, so i cut the siren, now it constantly makes a ckilcking noise and i can't start my truck, should there be a reset button on it..???
please help stuc without my truck...
Username: Shepyjay
Ont
Post Number: 45
harvey pull the fuses on the alarm brain.
Username: Shepyjay
Ont
Post Number: 46
kev you need a 555L or a 556L to bypass the ign factory alrm goto an directed authorized dealer to purchase this modual.
Username: Lsmith
Preston
United Kingdom
have you got a wireing diagram for a meta m99t2 car alarm please
kev20
Jay. Thanks for the info. I have bypassed the security so that it starts without the alarm going off.
However, sometimes the alarm goes off when I open the doors after unlocking them with the remote starter fob. Does the unlock need to bypass the security too? If so, how?
Username: Goose5714
Post Number: 311
Where's hazel crest at???
Username: Goose5714
Post Number: 315
aww near chicago...way to far
Home > Message Board > Car Audio > Security Systems > Archive through March 15, 2006 > Need some help or advice on car audio... [ « Previous ] [ Next » ]
