Home > Message Board > Car Audio > Security Systems > Archive through August 18, 2006 > I have all the answers to just about ...
Author Thread: I have all the answers to just about everyones problems
Username: Stnebrdgecustom
Hazel Crest, IL
I'm just opening a alarm/stereo shop and who evers having problems or just questions feel free to ask!!
iLLusionaire
um.. i started my car and my car died in the morning but when i started it again it didnt' die but the alarm died.. it doesn't work even with the remote.. doesn't auto lock or n e thing. its a clifford on an integra 95
Username: Romic00
Post Number: 39
hey i got a question. I have a remotre car starter/alarm and i need help installing it. First of all my dodge ram has a factory alarm and how do i disable it? the remmote car starter doesn't have a wire for disarming the alarn. Can i just cut the factory alarm wire of? i don't need it anyway. Then do u have a diagram on how to hook up the second ignition wire with a relay?? thx
Username: Romic00
Post Number: 40
hey u still alive?
Username: Tdeaton1021
Near Tampa, Florida
Post Number: 1532
have you worked with DEI proximity sensors.... whats your opinion if so?
smitty 2006
hi mate iv just got a valor alarm and having trouble wiring it to the central locking i have a ford escort 1997 please help any diagrams for the wires
I have an older bmw 1988, with an alpine stereo. Battery went down and It is asking for a code. I have the code number, but how do you enter it to unlock the stereo.???
Username: Farguson
Justin, Tx
How do you set the clock on the kenwood kpc-mp528 car raido I got this one when I bought the car no books with it
Username: Mickeyb_1981
I have purchased a TOAD AI606 and am having a few problems. I got a mechanic to install the alarm as he has the same model in his car and have installed a few others.
The alarm seems to be working however the central locking does not seem to be working.At first it works ok, but after a few hours it will not unlock the door.
Any ideas?
Username: Jamie1802
Orlando, Fl
Hi. I have had a viper alarm for 2 years and now when I lock and unlock it, the remote still beeps but I can hardly hear the car beep anymore, is this something I should be worried about? Also, when this first started happening, the factory cd player stopped working for a little while, not sure if the problem is related.
Username: Jamie1802
Orlando, Fl
Jerry, did you try setting the clock while the radio is turned on, that's the trick to setting the clock in my car.
Username: Grafixjoe
So...where the hell are U, CHRIS?!?!?!
Username: Phil1983
can u help wiv a wiring giagram 4 the clifford concept 300 pls? lost mine wen i moved home please e-mail me at
phillip_eames@hotmail.co.uk
thanks
Username: Leigh1sony
hi i jusT changed my Battery in my coBra alarm and now iT doesnT work please help
Home > Message Board > Car Audio > Security Systems > Archive through August 18, 2006 > I have all the answers to just about ... [ « Previous ] [ Next » ]
