Thread: My equalizer |
Silver Member Username: Bga44
Tampa,
FL
Post Number: 198 Registered: Nov-05
| Posted on Tuesday, January 03, 2006 - 08:39 pm: |
i have a 7band power acoustik equalizer. When i connected it to my bros system it wasnt as loud as it was without the EQ. What is the problem with that? |
Silver Member Username: Mrdark
Post Number: 174 Registered: Dec-04
| Posted on Tuesday, January 10, 2006 - 12:16 am: |
maybe the EQ isnt set right or the line out signal somehow was dilluted/reduced in voltage a bit? anyone else? |
New member Username: Nypdlapd
Post Number: 2 Registered: Feb-06
| Posted on Tuesday, February 28, 2006 - 04:46 pm: |
wirin could be wrong>>>>>> Is it amplified |
Platinum Member Username: Glasswolf
Wisteria,
Lane
Post Number: 11272 Registered: Dec-03
| Posted on Tuesday, February 28, 2006 - 05:33 pm: |
pre-out voltage may be lower, or the EQ may have an attenuator that needs to be turned up (master level or volume control)
Bronze Member Username: Kevin420
Gilbert,
Az
Post Number: 13 Registered: Apr-06
| Posted on Wednesday, April 05, 2006 - 12:49 am: |
any gain adjusts on the eq? |
