Thread: Half or quarter farad cap |
Silver Member Username: Vinnyqh
Portland,
OR
Post Number: 130 Registered: Nov-05
| Posted on Saturday, December 31, 2005 - 05:36 pm: |
does anyone know of a company other then monster that makes a half or a quarter farad cap? |
Silver Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 772 Registered: Feb-05
| Posted on Sunday, January 01, 2006 - 11:07 pm: |
there are plenty that make .5 farad caps, just try ebay. |
Portland,
OR
Post Number: 131 Registered: Nov-05
| Posted on Monday, January 02, 2006 - 02:15 pm: |
i did, only monster shows up. anyone else? |
Stockbridge,
GA
Post Number: 777 Registered: Feb-05
| Posted on Monday, January 02, 2006 - 04:11 pm: |
are you looking for a particular brand?? whats wrong with Monster?? also, why not just get a 1 farad?? http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=637 http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14149 http://www.ikesound.com/product-product_id/3126
Portland,
OR
Post Number: 140 Registered: Nov-05
| Posted on Monday, January 02, 2006 - 07:46 pm: |
For some odd reson people on these boards don't believe in capacitors. I on the other hand truely do believe in them on an unregualted power supply, because of the voltage is stabalized at the cap, and will deliever 14.4 volts if your electrical system is good. Now when most people think of a cap they think of hooking it up to an amp. I have an amp that has a regualted power supply. That being said, there is one more power source taht is not regulated in the car. The headunit. I need a small one to run my headunit off of. It's kinda hard to hid a 1 farad cap behing your dash haha. And the thing about monster is, i hate them. I think the way they market their products is misleading, and i don't liek to give my money to them. I think i'd rather go with the lightning audio one. Oh one last thing, if you think i'm a nut over that, you're right :-) |
