Home > Message Board > Car Audio > Accessories > Archive through January 24, 2006 > ALT Help!!
Author Thread: ALT Help!!
Username: Sitinphat25
I have a 2005 chevy silverado with a 145 amp alt. and have installed a kicker kx1200.1 and kicker kx350.4. the factory alt has no chance so i was wondering what size i need to upgrade to...thanks for all replies
bump
Username: Theelfkeeper
Stockbridge, GA
Post Number: 778
the KX350.4 is 60 watts rms X 4 right??
if so, your pulling about 115 amps for the stereo.
its usually best to add the aditional amperage to the stock alternator's output, making that 260 amps. so i'd say try to find a 200-250 amp alternator. or bigger if you can, always nice to have extra head room.
lawhozaher
ok how dose your kicker amps have no chance with that big of an alternator i'm running a 3000 watt amp and a 105 alternator and have no problems in a 95 beretta z26
Home > Message Board > Car Audio > Accessories > Archive through January 24, 2006 > ALT Help!! [ « Previous ] [ Next » ]
