Home > Message Board > Car Audio > Accessories > Archive through January 24, 2006 > If my alternators gives 12.5 above id...
Author Thread: If my alternators gives 12.5 above idle is it bad or it's normal?
Username: Panamanian
Panama city
Panama
Post Number: 142
say at 1500 ~ 2000 rpm my alternator indicates 12.5 is it normal? or something is damaged?
gracias
Username: Theelfkeeper
Stockbridge, GA
Post Number: 760
should be at 13.8 at idle and 14.4 above 1000 - 1500 RPMs. does it do that always or just when you have your stereo and stuff going??
Panama city
Panama
Post Number: 143
always, when i replaced my battery, that's what it was reading (12.5) at 1500rpm aprox. (i was pushing the accel. a little bit)
Username: Glasswolf
Wisteria, Lane
Post Number: 10819
alternators are 12.5 volts or so at idle. should be 13.8-14.4 above idle.
if it's staying at 12, it's not charging your battery.
the forward bias voltage has to be greater than the battery's charged voltage in order to recharge the battery.
make sure you test at the battery terminals though.
if that 12 volts is inside the car it may be a circuit with a regulated voltage.
Home > Message Board > Car Audio > Accessories > Archive through January 24, 2006 > If my alternators gives 12.5 above id... [ « Previous ] [ Next » ]
