Home > Message Board > Car Audio > Accessories > Archive through January 24, 2006 > Need a capacitor
Author Thread: Need a capacitor
Username: Ilyawizard
Post Number: 19
I have 4 Infinity speakers 100WRMS with an amp, and getting two infinity 10" 350WRMS SVC 4 Ohm with an infinity 611a amp, which generates about 657RMS at 2 Ohm load. So now I need a capacitor, and it better not cost too much, probably around $100 I guess would be enough. Any suggestions what kind of capacitor would be good? And also do I need more then one cap? If yes how do I wire few of them?
Username: Tjmutlow
Post Number: 694
most of them are the same, should need just one
Post Number: 20
1 farad?
Username: Tjmutlow
Post Number: 701
yes
Username: Star_of_god
Dayton, Ohio
i got one at Meijer for 50 bucks. My experience with this kind of stuff is that it is just as good from meijer as it is from best buy
Username: Rideredder
Cornell, IL
Post Number: 145
www.internetsoundsolutions.com has 1.5F for $35.00 plus shipping, if you don't mind buying off the internet. This is where I bought mine.
if u can get a cap off the internet the possabilitys are limit less my suggestion is get a 2 farad cap just in case u ever want to add another sub or somnthing like that but a good place 2 get a cap is www.sonicelectronics.com now the cheap caps are fairly expensive but when u get into a 5 or 6 farad cap there a great deal i got a 5 farad cap for $85 by powerAcoustik and it works great heres the big help DONT BUY IT IN A STORE THERE WAY OVER PRICED but if ure really skimpy then u can prolly get away without haveing a cap i ran 2 400 watt audiobahn's without one for a of months
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 3856
"i ran 2 400 watt audiobahn's without one for a of months"
U could have done it for longer
Home > Message Board > Car Audio > Accessories > Archive through January 24, 2006 > Need a capacitor [ « Previous ] [ Next » ]
