Thread: I need help plzz don'w wanna blow up anything |
New member Username: Williestylez85
Post Number: 2 Registered: Dec-05
| Posted on Tuesday, December 27, 2005 - 04:32 am: |
hello i'm new here i have 6 10"in subs 2=Audiobahn AW102T 450 rms and 900 max each 4=Audiobahn AW1051T 350 rms and 600 max each 2 amps 1=1000 watts xplod 2ch. 1=4000 watt legaxy 2ch. and a 62 amp alternator yellow top batt. i heard alot of ways to go about hooking it up to my 87 nissan pathfinder. but what all do you think i need to do to get the light from dimming i have not hooked up the second amp because i don't know how. so basically i have 2 subs running of the xplod right now and waiting to hook up the other 4 and the other amp plz help i don't want to ruin my future bad system somebody help me plz!!!!!!! |
Silver Member Username: Redliner
Wilmington,
Ma
Post Number: 354 Registered: Jun-05
| Posted on Friday, December 30, 2005 - 08:40 pm: |
what kind of subs are they and your going to need a ho alt what coil configuration are the subs so on |
Silver Member Username: Fandim
Reno,
Nevada
United State...
Post Number: 552 Registered: Jun-05
| Posted on Friday, December 30, 2005 - 09:03 pm: |
Well, you're going to ruin your alternator, big time, if you hook up another amp to that. Also, your voltage will start dropping so low, that you're system will start shutting off for a second before coming back on... (once you drop below 10.5 volts, most head units wont continue playing, instead turn themselves off.) First off, get a high output alternator. Second, with that many subs, and the type of system you're looking for, my best advice to you, honestly, is have a professional do the installation for you, so you dont destroy anything, or hurt yourself or your vehicle. Seth |
