Thread: Will my sub blow up one day |
Silver Member Username: Killerzracing71
Fredericksbutg,
Virginia
United states
Post Number: 212 Registered: Aug-05
| Posted on Monday, December 26, 2005 - 09:03 am: |
hey guys i have a Mb quart 15 not sure the model but the vc is one that can goe from 2-8 dual 2ohm i gues anyway its at 2ohm running by a mb quart Raa1000 which gives the sub 500 watts, by the way my sub doesnt sound as good as freind i have which has the identical setup except he has the sub that makes a 1ohm load(i blew mine) any way i cant even sit in the car for a very long time is ther alot of variables, for one he has a over 3cuft sealed box they recommend 1.5cuft and my car is huge, he has a protege is that it or would a large box help two my question is that the sub sounds like a cricket is inside it, and i was wondering if i hook another mb quart (same vc) to make a 1ohm load (1000rms) watts will it cause my sub to blow quicker help me befor the sale at re is gone i want sx 15 or 18 but dont feel like spending money bout to get an xbox360 cheap |
Relevant Product Info
Silver Member Username: Tjmutlow
Post Number: 642 Registered: Sep-05
| Posted on Monday, December 26, 2005 - 09:22 am: |
if it goes from 2 to 8 it is a dual 4 sub.. and yes get another dual 4 15, |
Fredericksbutg,
Virginia
United states
Post Number: 217 Registered: Aug-05
| Posted on Monday, December 26, 2005 - 09:42 am: |
i already got the other sub to make a 1ohm load just dont have a box and my trunk is shaped weird its large but its not flat can u help me out will it die on me |
Gold Member Username: Bestmankind
Los Angeles,
CA
Post Number: 1558 Registered: Oct-05
| Posted on Monday, December 26, 2005 - 12:01 pm: |
make a little platform so the box can sit on top of it. that way it will be flat. how is the height of your trunk? |
Fredericksbutg,
Virginia
United states
Post Number: 218 Registered: Aug-05
| Posted on Monday, December 26, 2005 - 03:07 pm: |
the subs are too big too make a box on a platform and the hump is to huge thats not the bulk of my question thanks for the suggestions will my subs be stressed if i give it 1000rms watss |
Post Number: 648 Registered: Sep-05
| Posted on Monday, December 26, 2005 - 04:06 pm: |
your not even going to see 1000w unless you have it at 14.4 and your running 2 subs, they will be ok. it is not always the amp, but that"finger" on radio that is most peoples problems. |
Fredericksbutg,
Virginia
United states
Post Number: 220 Registered: Aug-05
| Posted on Monday, December 26, 2005 - 04:18 pm: |
ok i know that i needed to run both subs to make 1ohm but what kind of power do you think my amp will make Mb quart raa 1000 at say 13.5 i have mesuared that, but i dont know how much current is going through how can i know i want a h.o. alt soon |
Post Number: 650 Registered: Sep-05
| Posted on Monday, December 26, 2005 - 04:21 pm: |
you might see 400 or so, it will be fine. |
Fredericksbutg,
Virginia
United states
Post Number: 221 Registered: Aug-05
| Posted on Monday, December 26, 2005 - 04:30 pm: |
400 man what how did you come up with that number this is not sony, or audiobahn i said MB. QUART RAA 1000 |
Gold Member Username: 54danny54
Betsy layne,
Kentucky..
USA duh
Post Number: 1320 Registered: Nov-04
| Posted on Monday, December 26, 2005 - 07:36 pm: |
killerzracing...from wat i hear, Xbox 360's are over rated lol...just get the SX and find a 360 on ebay l8er lol |
Post Number: 667 Registered: Sep-05
| Posted on Monday, December 26, 2005 - 09:04 pm: |
sorry 400 per sub, and besides If i remember, i was told that that amp is almost identical to the fosgate bd1000, because fosgate owned MBQuart not that long ago, either way it has to be ran at the correct voltage to see that, it may be even more, but you should be ok anyhow. |
Fredericksbutg,
Virginia
United states
Post Number: 224 Registered: Aug-05
| Posted on Wednesday, December 28, 2005 - 08:51 am: |
o i was bout to cry ty mutlow. as for the xbox i just want one, everyone has something to say bout it but i like it. everyones used to seeing the playstation thats what i think a 360 on ebay when i can go buy one today for $300 plus a nfs wost wanted as for the sx i am tired of spending money on subs, i need a ho alt now i think its pushing my electrical system a little hard i want to do a dual alt setup so i can leave my stock one hooked up and use the second for acc. like the amp and junk but the hardest part is brackets and belts
