Home > Message Board > Car Audio > Accessories > Archive through January 24, 2006 > Why does the little box cost 10bucks??!!
Author Thread: Why does the little box cost 10bucks??!!
Username: C10_250
Post Number: 12
I was wondering if anyone know the purpose of the box on the end of this:
http://cgi.ebay.com/PIONEER-CD-RB10-IP-BUS-TO-RCA-ADAPTER-INTERCONNECTOR_W0QQite mZ5845019463QQcategoryZ32809QQrdZ1QQcmdZViewItem
And if i would notice any difference by using this one.
http://cgi.ebay.com/NEW-PIONEER-AUXILLARY-ADAPTER-FOR-IP-BUS-RECEIVER_W0QQitemZ5 846377498QQcategoryZ60208QQrdZ1QQcmdZViewItem
Username: Tjmutlow
Post Number: 631
no diffeence
Username: C10_250
Kailua, Hawaii
Post Number: 13
Thanks, so I'm assuming the ones that are even cheaper than the one I posted will do just as well.
Username: Islandboy808
Mililani, Hawaii
US
Post Number: 335
hey wassup officer manoa,aloha from hawaii.
PimpSystem
ouch, hook thoes babes up wrong and your in a world of sh!t, could potentially blow ur amp if you put them on wrong,
Username: Tjmutlow
Post Number: 792
what are you talking about, not likely, it is just an adapter, that does not even hook into the amp!
Home > Message Board > Car Audio > Accessories > Archive through January 24, 2006 > Why does the little box cost 10bucks??!! [ « Previous ] [ Next » ]
