Thread: My alternator criessssssss while starting my car.  |
Silver Member Username: Panamanian
Panama city Panama
Post Number: 130 Registered: Aug-05
| Posted on Saturday, December 24, 2005 - 08:04 pm: |
After I installed my amplifier, and subwoofer, and do start to my car, the alternator belts screams soooooo hard, for a time then it stops. It's stock (70amp) using 2 rear speakers (80w rms each). 2 front speakers (stock) 1 amp (500w rms) 1 10" sub (330w rms). cable 8 gauge for amplifier (kit 2). should I replace the belt? or even with a new one the "screams" will be present? |
Silver Member Username: B101
Queen City,
NC
Post Number: 217 Registered: Sep-05
| Posted on Sunday, December 25, 2005 - 06:42 pm: |
sounds like the belt is slipping, replace it first |
| Posted on Friday, January 06, 2006 - 09:18 am: |
no its the fuse for the alternato in the fuse box get a bigger 1 (fuse) |
Gold Member Username: Carguy
Post Number: 5137 Registered: Nov-04
| Posted on Friday, January 06, 2006 - 10:03 am: |
Check the alternator belt. It could be loose or out of place. If it's worn, replace it. |
Panama city Panama
Post Number: 174 Registered: Aug-05
| Posted on Friday, January 06, 2006 - 11:25 am: |
I replaced it and no more "cry". gracias |
Queen City,
NC
Post Number: 316 Registered: Sep-05
| Posted on Saturday, January 07, 2006 - 01:09 am: |
no problemo |
