Thread: Yup..., installed my system and my lights dim a little bit |
Silver Member Username: Panamanian
Panama city Panama
Post Number: 127 Registered: Aug-05
| Posted on Saturday, December 24, 2005 - 01:07 am: |
When or How do i know when it's too much, or very risky for my alternator, electric / electronics devices or even amp/sub/speakers continue playing my songs??? I guess it's normal that lights dim a little bit (with engine in idle) |
Silver Member Username: Fandim
Reno,
Nevada
United State...
Post Number: 547 Registered: Jun-05
| Posted on Saturday, December 24, 2005 - 02:00 am: |
If you're dropping your battery below 12 volts, you will destroy it, and then it will destroy your alternator. (Unless you're using a deep cycle battery). If your lights are dimming, you should really consider a HO alternator..it does make quite a bit of difference in the sound quality too, if you're not currently able to supply the power the amps in your ride are demanding. Seth |
