Thread: Will i need a cap? |
New member Username: Hedgeut
Tn
Post Number: 5 Registered: Dec-05
| Posted on Thursday, December 22, 2005 - 03:45 am: |
i have an 06 denali and will soon be running 2 kicker L7's and a kx2500.1 amp. i will also install an optima yellow top. will i need a cap? also i am running my factory bose nav head unit... will i be able to have this system with this factory head unit?
Bronze Member Username: Blue_tornado_1
Woodbridge,
VA
Post Number: 11 Registered: Dec-05
| Posted on Tuesday, December 27, 2005 - 10:48 pm: |
ya u need a cap. r those 10s 12s 15s ? |
Silver Member Username: Fandim
Reno,
Nevada
United State...
Post Number: 550 Registered: Jun-05
| Posted on Wednesday, December 28, 2005 - 01:47 pm: |
Dont worry about a capacitor until you get a high output alternator. |
Silver Member Username: Dustin3
Tigard,
Or
U.S.
Post Number: 189 Registered: Oct-05
| Posted on Thursday, December 29, 2005 - 02:15 am: |
dont get a cap. it puts more strain on ur alt. get a 230 + amp alternator first |
Silver Member Username: Southern_bass
Paris,
Tennessee
U.S.
Post Number: 463 Registered: Dec-05
| Posted on Thursday, December 29, 2005 - 11:21 pm: |
Blue Tornado Bronze Member Username: Blue_tornado_1 woodbridge , VA Post Number: 11 Registered: Dec-05 Posted on Tuesday, December 27, 2005 - 10:48 pm: -------------------------------------------------------------------------------- ya u need a cap. r those 10s 12s 15s ? whats up with that ^^ ? |
Silver Member Username: Tjmutlow
Post Number: 747 Registered: Sep-05
| Posted on Thursday, December 29, 2005 - 11:54 pm: |
Youll prob need more then a cap, I would go with an alternator and a batcap 400. |
TheCobra Unregistered guest |
| Posted on Friday, December 30, 2005 - 10:35 am: |
Don't, lots of people have advised me that itsn't worth it. Just buy a stronger battery and a bigger alternator... |
SLAPP EM BASS Unregistered guest |
| Posted on Friday, December 30, 2005 - 12:19 pm: |
yea jsut buy a better alternator.prolly gonna cost u more than a cap but its gonna b for yer own good...caps are nothing but trunk jewelry..it takes power from the alternator also, so forget that piece of junk...or even maybe get a smaller amp like 1200.1 u might not even need to get your alt changed.. |
Platinum Member Username: Glasswolf
Wisteria,
Lane
Post Number: 10818 Registered: Dec-03
| Posted on Friday, December 30, 2005 - 02:04 pm: |
read and expand they enlightenment http://www.wickedcases.com/caraudio/capacitors.html http://www.wickedcases.com/caraudio/charging.html http://www.betteraudio.com/geolemon/newmain/battcapalt/ http://www.bcae1.com/charging.htm http://www.bcae1.com/chargin2.htm http://www.wickedcases.com/caraudio/batteries.html http://www.the12volt.com/info/recwirsz.asp http://www.optimabatteries.com/
