Thread: How do I wire this system right? 2amps,2subs,2peakers,compacitor? |
Bronze Member Username: Bradrgilman
GALvEStoN ,
Tx
Usa
Post Number: 89 Registered: Nov-05
| Posted on Monday, December 19, 2005 - 01:58 am: |
I am going to re-do my systems wiring because I know it is not right. What is the best way to wire this system, there is a lot to wire? I have- 2 12" 4 ohm L7 Subs 2 great kappa 6x9's 2 amps- 1 mono Planet Audio VX2250D amp and 1 planet audio VX6005 5ch amp. 4ch for speakers and 1 sub output. 2 tweeters 1 farad compacitor Kenwood KDC-MP5028 head unit 4 gauge wire and 12 gauge speaker wire What would be the best way to wire this? Would it be both subs to 1 ohm with sub amo and bridge the other amp to the 2 speakers and use the sub output channel on the 5 ch amp to the subs too, head unit to tweeters? Thanks a lot! |
Silver Member Username: Tjmutlow
Post Number: 489 Registered: Sep-05
| Posted on Monday, December 19, 2005 - 06:47 am: |
you are going to use just 4 channels on that amp, and if the kappas are new, they are 2 ohm speakers, so. you can not bridge that amp. I would run the tweets on the other 2 channel with bass blockers and the subs on the mono amp. |
GALvEStoN ,
Tx
Usa
Post Number: 90 Registered: Nov-05
| Posted on Monday, December 19, 2005 - 01:43 pm: |
So, would I be better off selling the 5ch amp and buying a 2ch amp for the kappas and running the tweeters off the head unit? Okay, so you cant bridge a 4ch amp to the Kappa's or any other 6x9's or how do you find out if you can? Thanks |
Post Number: 510 Registered: Sep-05
| Posted on Monday, December 19, 2005 - 01:59 pm: |
you can, just as long as they are a 4 ohm load, i would run that 5 channel since you have it now, use channels 1,2 for the kappas, and 3,4 for the tweets using a bass blocker on them, and gain down.Remember almost all amps are rated at 4ohm bridged and 2ohm stereo modes.The new kappas are like the only 2ohm speaker I know of, it is new to the 05 line |
Post Number: 512 Registered: Sep-05
| Posted on Monday, December 19, 2005 - 02:01 pm: |
i would keep the 5 channel(since you have it now), run the kappas off the 1,2 channels and dont you have front speakers, if so run those and the tweets to the 3,4 channel(bass block the tweets0 to create a 2ohm load on 3,4. |
Silver Member Username: Tdbdadrummer
Post Number: 780 Registered: Aug-05
| Posted on Monday, December 19, 2005 - 10:53 pm: |
Out of curiousity, are they really called GREAT Kappa's or is someone Infinity biased O.o? |
Post Number: 781 Registered: Aug-05
| Posted on Monday, December 19, 2005 - 10:54 pm: |
I just thought I'd mention I like the choice of HU as well. More people need to give Kenwood HU's a chance. They have really nice SQ. I personally like them better than Alpines and Pioneers for that reason. |
GALvEStoN ,
Tx
Usa
Post Number: 91 Registered: Nov-05
| Posted on Monday, December 19, 2005 - 11:20 pm: |
yeah they are really called GREAT Kappa's. You can only find them in Galveston. |
GALvEStoN ,
Tx
Usa
Post Number: 92 Registered: Nov-05
| Posted on Tuesday, December 20, 2005 - 01:51 am: |
Yeah, I like that choice, but if I sold the amp and got more and then I paid for a good 2ch amp for the kappas would that be even better? I am saying this because if it would be better or work as good, I could make money selling the 5ch. Thanks |
