Thread: Optima Yellow Top as Only battery? |
Unregistered guest |
| Posted on Sunday, December 18, 2005 - 11:27 pm: |
Hi. I used to have my Yellow Top Optima Deep Cycle battery in the trunk in addition to the stock battery up front. This was accomplished with an isolator. Although the isolator's max AMP rating was at least 10 or 20 amps higher than my stock GM alt output, the isolator bit the dust one hot AZ summer day (AC on max, 2 amps at max. My question is this: are Deep Cycle batterys recomended for daily driving / starting / bumping, even if car has only one battery? I had intended to replace the stock batt up front with the Optima YellowTop, untill my friend advised against it, saying (a deep cycle batt.) wouldn't last long as a car's exclusive battery. Is this myth true? help! thanx |
Bronze Member Username: Jth0033
Downingtown,
Pennsylvania
United States
Post Number: 13 Registered: Sep-05
| Posted on Monday, December 19, 2005 - 07:47 am: |
I have the same question, I was recommended to get an Optima Yellow Top battery as my primer battery rather than hook-up two batteries. Off of the Optima I will be running about 600 watts in subs and amps, and then I plan on adding a lcd flatscreen and gaming system. Will this battery be okay for all of that or would you advise me to hook up two? Would hooking up two batteries put a lot of strain on my stock alternator? |
Silver Member Username: Fandim
Reno,
Nevada
United State...
Post Number: 533 Registered: Jun-05
| Posted on Tuesday, December 20, 2005 - 10:33 am: |
I ran my car with no problems with just one yellow top under the hood, although I recently upgraded, adding my third total.. |
Gold Member Username: Carguy
Post Number: 5100 Registered: Nov-04
| Posted on Tuesday, December 20, 2005 - 10:58 am: |
Deep cycle batteries were designed for a different purpose than starter batteries. You CAN use them to replace your starter batteries, however, it will shorten it's life cycle. Why would you use $170+ deepcycle to start your car when the starter models are $80 or lower in cost?
Reno,
Nevada
United State...
Post Number: 541 Registered: Jun-05
| Posted on Thursday, December 22, 2005 - 04:32 pm: |
Well, for one thing, it's nice not to have to isolate your starter battery. To isolate a starter battery effectively, you literally have to have a piece to seperate the currents, and keep them on completely different circuits.. these arent very cheap. If you dont do this, and just use a normal isolator, like a solenoid for example (basically a relay) with a switch, whenever your car is running, and you want to have juice flowing to your back battery, if you ever start dropping it below 12 volts, you're going to damage the starter battery. Soon, the starter battery will not hold it's charge, and your car is not going to start..but for the short while it does, you'll be destroying your alternator, as well as putting a constant drain on your 2nd deep cycle battery as well. Once it really starts getting worse, your alternator and your other battery will both be killing themselves just trying to keep the starter battery at 12v. Seth |
