Home > Message Board > Car Audio > EQs and Crossovers > Archive through August 01, 2006 > Basics
Author Thread: Basics
Username: Racer501
ND
Post Number: 238
how does a crossover work im like lost in tho hole thing of high at 6 Db per octave or whatever it is i dont understand it would any one mind explaining it in a somewhat simple form
Username: Theelfkeeper
Stockbridge, GA
Post Number: 703
thats just the rate at which the sound slopes off or on. high rate means less overlap, steep cut offs, low rate means more overlap and slower cut offs.
theres a page on this on www.bcae1.com that shows the graphics i think. as far as whats best, i think a high slope is best for general installs where a low slope requires more in installation. don't know of any other pros or cons.
Jonathan is the speaker guy, lol, he'll know.
Username: Racer501
ND
Post Number: 239
well i thought i found the section on bcae1.com but i wasnt sure n i was like o.O when i looked at it so i started reading n i was lik O.o so yea i dont get how that is explained on there i have gotten alot info explained from there tho so i do have to admit it can help when ur understanding what there saying unlike me with the hole cross over thing
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 1944
Mr. Bill at caraudio.com explains it fairly well:
"Crossover Points I am sure you have heard the term 20 to 20 in refering to audio. Sound is just pulses of air pressure our ears can pick up. Frequencies are measured in cycles per second (Hz) which is just the number of pulses which happen each second. If your speaker moves back and forth 80 times in a second it is playing an 80Hz tone. It is generally acepted that the range of human hearing is 20Hz to 20KHz. KHZ is KiloHertz or 1000Hz. If you know piano, the fundamental tone for middle C on a Piano is about 263 Hz. You will not find any speaker anywhere which can produce 20Hz all the way up to 20KHz (that will fit in your car or that you can afford). That is why you use some combination of tweeters and woofers to reproduce sound. A typical 2 way component set will have the tweets covering notes from 3KHz-20KHz and the midbass covering from 80Hz-3KHz. The sub covers 20Hz-80Hz. In the system I just described the crossover points would be 80Hz (where the sub gives way to the midbass) and 3KHz ( where the midbass gives way to the tweeters)
Crossover Slopes In the above example I listed a midbass/tweeter crossover point of 3KHz. If I were to unplug my midbass speaker and play a 1.5 KHz tone I should not hear anything, right? Wrong. The hand off between two speakers is very gradual. If you take two speakers playing the exact same note at the exact same db, the result would be 3db higher than one speaker. Since the falloff of a speaker is gradual, the crossover point is the tone where both speakers are down 3db. There are a few common crossover slopes: 6db, 12db, 18db and 24db. These are know respectively as 1st order, 2nd order, 3rd order and 4th order. What does this mean? In my example from above, if the crossover slope was 3rd order (18db) it means that for every octave below the crossover frequency the sound fades off at 18db. So if we were to unplug our midbass and play a 1500Hz tone (one octave below 3KHz) it would be 18db below a 3KHz tone played into the tweeter.
tweeter attenuation In most car audio environments the tweeters end up very close to your ears while the mids end up further away. Since the tweeters and mids are playing at the same level it would make the tweeters sound louder than the mids since they are closer. This is why many crossovers will have tweeter connections for 0db, -3db, -6db etc... This allows you to lower the power to your tweets so you can match them to the volume of your mids. This is known as tweeter attenuation. FYI since every 3db drop is half power if you have your tweets set to -6db and running off a 100watt RMS amplifier you are actually only sending 25watts to your tweeters.
tweeter protection Like any speaker, if you stress them too much they will break. Some crossovers will have fuses installed between your amp and tweeters that will blow at a predetermined wattage to prevent you from blowing a tweeter.
impedence compensation [zobel network] This one is a bit harder to explain without getting into crossover design theory. Basically in order to design a crossover you need to know what the impedance of the speaker is. The components for a 3Khz, 6db slope crossover are totally different if you are using a 4ohm speaker rather than an 8ohm speaker. The problem comes into play near the resonant frequency of the speaker. As a speaker aproaches it's resonant frequency it tend to resist electricity more. For example, in a common 6ohm tweeter with a resonant frequency of 1Khz, the amplifier may see a 12 ohm load at 1Khz rather than a 6ohm load. This REALLY messes with crossovers because they suddenly see a 12ohm load and their crossoover point changes for that moment!!! A zobel network is normally used when you are driving tweeters down to a point near their resonant frequency. It is a set of components which divert power through a resistor near a particualr frequency (normally tuned to the resonant frequency of the tweeter) so as to show the crossover and amplifier a more consistant resistance.
good stuff as always squeak. and thank you mr bill, that all seems on the mark.
but people (even myself sometimes ) wont understand what a 'crossover slope' is, unless they SEE a graph of both points, with the rolloffs. this is how they will understand, so this is my contribution.
Username: Mikechec9
Post Number: 1945
notice what he says about actually seeing the slope. that's what makes it a lot clearer.
Username: N2audio
Lawrence, Ks
Post Number: 266
http://www.bcae1.com/xovrslop.htm
Username: Racer501
ND
Post Number: 260
thanks aload mike that helped out so much the only thing i dont get is the last paragraph about impedence compensation but i get crossovers so much better now thanks a load!!
Username: Mikechec9
Post Number: 1961
sweet
Username: Racer501
ND
Post Number: 264
k i think i got that last paragraph now... when the speaker hits its resonant frequency it resists power more increasing the ohms making the cross over change n stuff cutting off the frequency for a lil while or w/e .....yes?
Home > Message Board > Car Audio > EQs and Crossovers > Archive through August 01, 2006 > Basics [ « Previous ] [ Next » ]
