Home > Message Board > Car Audio > Amplifiers > Archive through December 18, 2005 > Which draws more current?
Author Thread: Which draws more current?
ih8dimminglights
which amp would draw more current from the alternator?
2ch 800 wrms class AB amp hooked up to 2 subs or
1000wrms class d mono amp hooked to 2 subs.
Username: N2audio
Lawrence, Ks
Post Number: 40
It would be pretty close.
Figuring on full power efficiency - a/b will be around 60% and D will be around 75% so...
800/.6 = 1333
1000/.75 = 1333
Pretty close I'd say.
Overall though, the class D will be less draw to the alt because their efficiency is relatively linear at all output levels whereas a/b are most efficient at full power and get less and less effecient as volume nears zero.
Home > Message Board > Car Audio > Amplifiers > Archive through December 18, 2005 > Which draws more current? [ « Previous ] [ Next » ]
