Home > Message Board > Car Audio > Amplifiers > Archive through December 18, 2005 > What amp for these speakers?
Author Thread: What amp for these speakers?
Username: Swervinburbin
Bronx, New York
Post Number: 28
I am ordering diamond audio component speakers. Before i order them i want to know what amp i will need for them.
http://cgi.ebay.com/DIAMOND-AUDIO-S600A-6-1-2-Component-System-ALUMINUM-TW_W0QQi temZ5841222618QQcategoryZ32819QQrdZ1QQcmdZViewItem
Username: Theelfkeeper
Stockbridge, GA
Post Number: 695
wow, thoes are some pretty high ratings. you don't need a couple hundred watts of power though. anything around 100 watts will be plenty. what else do you have in your car?? subs?? that'll give us a good idea of how many watts you might need to keep up with the subs so the components don't get drowned out.
Bronx, New York
Post Number: 29
I have a pioneer premier dehp860mp HU and 2 RF 12 inch p1s and a RF 3001 amp.
Username: Vinnyqh
Portland, OR
Post Number: 103
Very good choice on speakers, if it was my car, i would get the s600s (silk dome tweeters vs. aluminum done).
If you are running jsut front speakers no rear fill i would go with the d6600.4 then bi amp the fronts. Or if you have enough money then the d9800.2. But that would be overkill.
Home > Message Board > Car Audio > Amplifiers > Archive through December 18, 2005 > What amp for these speakers? [ « Previous ] [ Next » ]
