Thread: What can i do? |
New member Username: Liqdfire3
Lee high acres,
Florida
Post Number: 9 Registered: Sep-05
| Posted on Saturday, December 17, 2005 - 03:12 pm: |
i have a 12" Q Power deluxe series subwoofer 4ohm DVC. the question i have is if my old amp, a boss riot rt745 rated at 250w rms bridged, will be enough to push my sub and not blow or overheat. i have a power acoustik a2400db class d amp, but i dont want to put it in my truck till i get my new subs. |
Silver Member Username: Tjmutlow
Post Number: 438 Registered: Sep-05
| Posted on Saturday, December 17, 2005 - 03:35 pm: |
If that boss is a 2 channel you should not use it if the sub is configured to a 2ohm load, will burn it up. |
Lee high acres,
Florida
Post Number: 10 Registered: Sep-05
| Posted on Saturday, December 17, 2005 - 03:37 pm: |
the amp is 4 channels but can be bridged to 2 channels at 250 rms |
Post Number: 440 Registered: Sep-05
| Posted on Saturday, December 17, 2005 - 03:38 pm: |
that amp can not handle a 2ohm load bridged, only stereo. |
Bronze Member Username: Liqdfire3
Lee high acres,
Florida
Post Number: 11 Registered: Sep-05
| Posted on Saturday, December 17, 2005 - 03:40 pm: |
what if i didnt wire the sub to 2 ohm? |
Post Number: 442 Registered: Sep-05
| Posted on Saturday, December 17, 2005 - 04:58 pm: |
it would be an 8ohm load so cut the power in half of what the 4ohm load would produce. |
