Home > Message Board > Car Audio > Amplifiers > Archive through December 18, 2005 > Speaker Wattage
Author Thread: Speaker Wattage
Username: Mwright1000
Post Number: 93
Is there anyway I can figure out how many watts my speakers are putting out? I want to know so I don't blow them. Also what's the easiest way to measure db's. Is there a meter or something I can buy? If so where can I get one? Thanks
Username: Tjmutlow
Post Number: 426
speakers do not put out watts.
Post Number: 94
Ty that's a pretty vague answer. OK so I am wrong on this, what do they put out then? They are rated for watts, correct? Also do you have an answer to my other question.
THanks
Username: Islandboy808
Mililani, Hawaii
US
Post Number: 246
your amp puts out watts.so maybe something to bench ur amp.
Los Angeles, CA
Post Number: 1361
martin do you mean how much watts your speakers can handle?
Post Number: 96
I want to figure out what my speakers are pushing. They are rated at 40rms. So how can i find out what they are pushing so I can tell how close I am to going over the rms rating.
THanks
Username: Tjmutlow
Post Number: 428
they do not push anything, watss are what they can handle and amps push out watts based upon, ohm load and current supplied to amp
Home > Message Board > Car Audio > Amplifiers > Archive through December 18, 2005 > Speaker Wattage [ « Previous ] [ Next » ]
