Home > Message Board > Car Audio > Accessories > Archive through January 24, 2006 > Install kits
Author Thread: Install kits
Username: Swervinburbin
Bronx, New York
Post Number: 24
I got my system installed the other day at best buy and they charged me $310 for a head unit, an amp, and wires, DO they sell kits so i can do it myself. I have basic wiring knowledge. I know about amp kits but do they have kits for everything else you need?
Bronx, New York
Post Number: 25
oh also 2 subs
Username: Vinnyqh
Portland, OR
Post Number: 98
Most kits do have everything for the power side of things. Sometimes you have to buy RCA's also. Most places have all the different kits for you dash harness and you dash kit, amp kits, i mean they are a store.
What kind ofa system did you get for 310 dollars?
Bronx, New York
Post Number: 27
Oh no that is how much they charged to install it
Username: Greeney
Grove, MN
US
Post Number: 124
:/ ^^ ehh u should have asked someone here to help u man!
1. take power cable from battery to amp
2. ground HU
3. attach Remote Wire and run wire to amp
4. attach RCA wires from HU to your amp
5. ground your amp
6. speaker wire to sub(s) + and -
7. put your fuse in your fuse block
and you should be bumpin
Username: Tjmutlow
Post Number: 566
if it is already instralled, then why do you need a kit
Bronx, New York
Post Number: 35
I want to install subs in my dads car
Username: Star_of_god
Dayton, Ohio
dude I bought a wiring kit at Meijer for 24.99 and it's just as good as one from best buy. I even bought a capacitor there for 50
Username: Tjmutlow
Post Number: 862
Attention: not all wiring kits are the same... they are made with differnet materials and strand counts....
Home > Message Board > Car Audio > Accessories > Archive through January 24, 2006 > Install kits [ « Previous ] [ Next » ]
