Home > Message Board > Car Audio > Amplifiers > Archive through December 18, 2005 > Power wire for 2 amps.
Author Thread: Power wire for 2 amps.
Username: Hootz
Saskatoon, Saskatchewan
Post Number: 74
I've got an Alpine MRD-M1005, and an MRV-F345. Total wattage is about 1400 wrms. I bought the f345 a few months after so I had already bought 4 guage for the m1005. I just want to run 1 wire to a distribution block, but will 4 guage be enough? Most specs say it's good enough for 1400 watts, but is that cutting it too close?
Username: Hootz
Post Number: 76
bump
Username: Infinity_addict
Santa Rosa, California
Post Number: 213
your safest bet is to run 0guage to the back, and split it into two 4guage lines. if yer running yer subamp at 4ohms (700W RMS), i SUPPOSE you could run 2guage to the back and split it into two 4guage lines, but i'd still reccommend 0guage.
yes 4 guage can handle 1300W RMS, but only up to 10ft, so unless yer driving a clown car...
Take a look at this chart to determine what you need.
http://www.crutchfieldadvisor.com/learningcenter/car/cable_gauge_chart.html
Username: Rovin
Trinidad & T...
Post Number: 3836
http://www.the12volt.com/wiring/recwirsz.asp
Home > Message Board > Car Audio > Amplifiers > Archive through December 18, 2005 > Power wire for 2 amps. [ « Previous ] [ Next » ]
