Thread: Amp channel setup questions. |
New member Username: Palanza
Post Number: 7 Registered: Dec-05
| Posted on Wednesday, December 14, 2005 - 08:16 pm: |
Ok, so I have a 520 watt 4 channel amp. The plan is, to have 2 channels powering my components. One for each set. Then, to bridge a channel and have it power my sub. Is that a good idea - because with this setup I cannot independently control the volume of the sub/components. My sub is rated at 175 watts RMS, and the amp is going to be pushing 220ish to it. So thats why I'm afraid if I turn up my speakers, I'm going to toast my sub. What do you think? (Kappa Perfect Components) (RE RE12 Inch Sub Sealed) |
Bronze Member Username: Palanza
Post Number: 11 Registered: Dec-05
| Posted on Friday, December 16, 2005 - 03:33 am: |
Bah, any opinions? |
Silver Member Username: Tjmutlow
Post Number: 409 Registered: Sep-05
| Posted on Friday, December 16, 2005 - 06:35 am: |
that sub needs to a single 4ohm sub. Some amps have to gains, does yours. |
Post Number: 13 Registered: Dec-05
| Posted on Saturday, December 17, 2005 - 06:46 pm: |
Ok, well let me state this again. That is what Im able to do right now, so is it going to be a problem - and yes, I am pushing 4 ohms to my sub mutlow. |
Silver Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 696 Registered: Feb-05
| Posted on Saturday, December 17, 2005 - 08:48 pm: |
shouldn't be a problem. an extra 45 watts isn't gonna blow that sub, unless your clipping. just make sure the gains are set appropriatly and that you have the crossovers, HU or Amp, set right. |
Post Number: 449 Registered: Sep-05
| Posted on Saturday, December 17, 2005 - 10:26 pm: |
do you have 1set of components=2mids, tweets etc, because 2 sets of components is 4 mids, tweets, etc. those kappas are 2ohms, so you have to run them stereo mode on any amp. |
