Home > Message Board > Car Audio > Amplifiers > Archive through December 18, 2005 > How to hook up speakers
Author Thread: How to hook up speakers
Bad_Azz_Bowtie
2 dual 4 ohm massive audio Ref series subs. hooked to a 1500.1 massive audio amp. what is your recommended way to run these?
Username: Carguy
Post Number: 5053
Wire each sub in parallel for 2ohms, and then in series with each other. That should give you 4ohms resistance.
Username: Rovin
Trinidad & T...
Post Number: 3769
Isaac - great to see u back on the forum !
Alot of ppl are looking out to ask u your opinion ...
Username: Carguy
Post Number: 5055
Thanks, I moved last month and couldn't get the internet in the new area till now.
Username: Mwright1000
Post Number: 86
How do you do that Issac? Wire the subs paralell then wire them in series together. You lost me, I guess.
Username: Carguy
Post Number: 5069
With dual VCs, they have 2 connectors per side. Connecting them in parallel will lower the resistance by half. In series, they will add.
Therefore, for 4ohms DVC, each sub in parallel will equal 2ohms. Now, both in series will give you 4ohms (pos to neg).
Post Number: 87
So, you are wiring pos(+) to pos(+) and neg(-) to neg(-) on each speaker. Then you are coming off the amp's pos(+) terminal and going to the neg(-) of each speaker then from the neg(-) of the amp to the pos(+) of each speaker. Is this right?? Sorry for all the q's but I want to make sure I understand this.
THanks!
Username: Carguy
Post Number: 5072
Correct on your first question, pos to pos and neg to neg on each speaker/sub. Then take pos from one sub and connect it to neg on the 2nd sub. Now use the connectors left from each sub.
Amp's neg goes to neg on one sub, and amp's pos to the other sub's pos.
Post Number: 88
Got ya!! Thanks alot, it's easy to understand now that it's explained!
Home > Message Board > Car Audio > Amplifiers > Archive through December 18, 2005 > How to hook up speakers [ « Previous ] [ Next » ]
