Thread: Amp for some jl audio xr650s |
Silver Member Username: Thigpen
RVA,
Va
Usa
Post Number: 351 Registered: Sep-05
| Posted on Tuesday, December 13, 2005 - 06:04 pm: |
going to be getting some for x-mas... was looking at kicker but theirs is all at 2 ohms... do i just divide the 2 ohm number in half to get the 4 ohm number? |
Silver Member Username: Tjmutlow
Post Number: 378 Registered: Sep-05
| Posted on Tuesday, December 13, 2005 - 06:07 pm: |
Use the jl 300/4 or the 450/4 |
Post Number: 379 Registered: Sep-05
| Posted on Tuesday, December 13, 2005 - 06:08 pm: |
at 4ohms what ever the amps mx cut it in half |
RVA,
Va
Usa
Post Number: 352 Registered: Sep-05
| Posted on Tuesday, December 13, 2005 - 08:44 pm: |
what about a 300/2... why do i need a 4 channel amp for a set of componets? i was probably just going to take the rear speakers out since ill have 2 12" SE's in the hatch and no one ever fits in the back of a 3000Gt anyway |
Post Number: 381 Registered: Sep-05
| Posted on Tuesday, December 13, 2005 - 08:53 pm: |
for that you can run the 250/1 |
Post Number: 382 Registered: Sep-05
| Posted on Tuesday, December 13, 2005 - 08:57 pm: |
never mind, brain fa..t.... |
RVA,
Va
Usa
Post Number: 353 Registered: Sep-05
| Posted on Tuesday, December 13, 2005 - 09:04 pm: |
150 each wont be too much power for 70rms speakers will it... |
Post Number: 383 Registered: Sep-05
| Posted on Tuesday, December 13, 2005 - 09:19 pm: |
no i am runnig the 450/4 on mine, just waitng on them to show up. |
RVA,
Va
Usa
Post Number: 356 Registered: Sep-05
| Posted on Wednesday, December 14, 2005 - 08:46 pm: |
just wondering if i was feeling cheap and didnt get the 300/2 what would be another good amp but in the 100-150$ range |
RVA,
Va
Usa
Post Number: 367 Registered: Sep-05
| Posted on Wednesday, December 14, 2005 - 11:21 pm: |
what about the kicker kx350.2 it does 175x2 at 2 ohms so thats about 87x2 at 4 ohms... would that run them good or should i go with more power? |
Gold Member Username: Bestmankind
Los Angeles,
CA
Post Number: 1344 Registered: Oct-05
| Posted on Wednesday, December 14, 2005 - 11:29 pm: |
you are going to love the way they sound cause i have those and they sound great. got mine hooked up to the jl450/4 though. |
RVA,
Va
Usa
Post Number: 368 Registered: Sep-05
| Posted on Wednesday, December 14, 2005 - 11:32 pm: |
how much of a difference would a kicker amp make over the jl... because the 350.2 is like 89 on ebay whereas the 300/2 is like 270...pretty big difference in money if it wont be a big noticeble diffence in sound.. my next question is how do you have them installed? |
