Home > Message Board > Car Audio > Amplifiers > Archive through December 18, 2005 > Amp for infinity subs
Author Thread: Amp for infinity subs
Username: Ilyawizard
Post Number: 16
So what would you recommend for 2 of my Infinity Kappa 10.1D subs 350 RMS each.
Username: Young_james
Post Number: 473
whats your budget?
Post Number: 17
I'm basically looking for the best offer, but around 300 would be nice.
Username: Homegrowncam
Watauga, TX
United States
Post Number: 135
You could go with the Infinity 611a
Post Number: 18
Are you sure 611a would be enough? I'm not an expert, but what I've researched so far is: 2 infinity subs are 350 RMS @ 4ohm double voice coil, and it either can be connected @ 1 Ohm, or @ 4 Ohm. Very little amps are 1Ohm stable, and 4 Ohm is more recommended. And 611a is 456 RMS @ 4 Ohm. Subs are 700 RMS together. Am I right on this one? If not please explain.
Username: Rovin
Trinidad & T...
Post Number: 3804
buy this
http://www.sonicelectronix.com/item_718.html
Home > Message Board > Car Audio > Amplifiers > Archive through December 18, 2005 > Amp for infinity subs [ « Previous ] [ Next » ]
