Thread: Need some opinions |
New member Username: Curious1
Post Number: 5 Registered: Dec-05
| Posted on Monday, December 12, 2005 - 10:27 pm: |
Hey guys do you think this amp will blow my subs http://cgi.ebay.com/NEW-JL-AUDIO-MONO-SUB-AMP-500-1-MONOBLOCK-CLASS-D-500-w_W0QQ itemZ5837839619QQcategoryZ79827QQrdZ1QQcmdZViewItem and i have two 12" audiobahns 500 watts rms and 1000 max and the part number is AW C12 T reason i asked is im trying to find the right match subs and amp im tired of problems i have a capacitator to 1.2 farad |
Silver Member Username: Safa19
Post Number: 185 Registered: Apr-05
| Posted on Monday, December 12, 2005 - 10:44 pm: |
that amps only 500watts rms so it would be good for one sub not powerful enough for 2 but then again you have audiobahn y not upgrade your subs and settle for an amp like orion or kicker. theres no point in having a top quality amp with not so good subs like audiobahn |
Bronze Member Username: Southern_bass
Jacksonville,
Florida
U.S.
Post Number: 51 Registered: Dec-05
| Posted on Monday, December 12, 2005 - 11:29 pm: |
thats a great amp...defianately upgrade those subs..look into 2 jl w3v2's |
Post Number: 6 Registered: Dec-05
| Posted on Tuesday, December 13, 2005 - 04:46 pm: |
so if i upgrade my subs to the jl's i should go with that amp |
Silver Member Username: Tjmutlow
Post Number: 376 Registered: Sep-05
| Posted on Tuesday, December 13, 2005 - 05:46 pm: |
that amp is alot stronger then what it says. i have it running 2 10w3 and not turned up very much. It can run w6's and if any questions go to jlaudio.com. |
Post Number: 7 Registered: Dec-05
| Posted on Tuesday, December 13, 2005 - 10:39 pm: |
ok guys im going to start over and end this thread can you all stop posting here and post in the thread titled "Taking all suggestions" |
