Thread: Old school hifonics amp help |
Silver Member Username: Terry6405
Sullivan,
IN
US
Post Number: 104 Registered: Sep-05
| Posted on Monday, December 12, 2005 - 12:51 pm: |
i have a old school atlas VII vari-power 400 watt amp. every time i turn up the volume, it goes into protect mode, how can i fix this? i took it apart and realized how little i really know about car audio. what should i do?
Gold Member Username: James1115
Wilton,
Ct
Post Number: 4351 Registered: Dec-04
| Posted on Wednesday, December 14, 2005 - 12:33 pm: |
has it worked in the past? are you sure the install is correct? could be a faulty ground, reversed polarity, power wire hooked up to remote wire, ect need more info. |
Gold Member Username: Carguy
Post Number: 5068 Registered: Nov-04
| Posted on Wednesday, December 14, 2005 - 02:19 pm: |
An amp can go into protection mode if over driven or under powered. For example, the power drops below 11v or you set the gain/level to 1v and send 4v. |
Sullivan,
IN
US
Post Number: 106 Registered: Sep-05
| Posted on Thursday, December 15, 2005 - 11:11 pm: |
it worked fine and i checked all the wires. it hardly takes any power b4 it goes into protect i think the gain was fine about 2.5--matched with the HU i just got a new battery and it didnt have enough power to make the alt drag is it just broke? |
Sullivan,
IN
US
Post Number: 108 Registered: Sep-05
| Posted on Friday, December 16, 2005 - 04:53 pm: |
i figued it out, reversed polarity, they need to make all speaker wire diferent colors so you can esily tell b/w +&- |
