Home > Message Board > Car Audio > Amplifiers > Archive through December 18, 2005 > Best match
Author Thread: Best match
Username: Monkey_man
Post Number: 404
okay here we go these are some amps that have been catching my attention lately. I need to find an amp that will match my idmax nearly perfect.
Phoenix Gold X1200.1
JL Audio e1800D
Orion-1200D
Alpine MRD-M1005
JBL BP1200.1
Autotek SX-1700X
Post Number: 406
bump
Post Number: 408
add the ed nine.1 to that list also...Can someone just give me a brief description on these amps? i mean the specs look pretty good im just tryin to see which will put out the best SQ.
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 3087
whats ur budget
Username: Vinnyqh
Portland, OR
Post Number: 68
Diamond Audio D61500.1
Post Number: 409
Basically, my budget is how much i feel like spending. I would like to keep it around 400(ebay) but if i go above 500 im gonna get a nikimachi.
Post Number: 410
by the way...my sub is dual 4 ohm.
Username: Rovin
Trinidad & T...
Post Number: 3745
according to Jon/Isaac that sub only needs around 800wrms 2 perform very well so rule out 1200wrms amps
Obviously dual 4ohms = a 2ohms load so look 4 any good amp that does around 1000wrms @ 2ohms
of those u listed Jl & Alpine would be my choice ...
Post Number: 411
Okay thanks...i was really thinking about the PG just because i could use it in the future. But the brand seems a lil iffy to mee. Or i might just break my wallet and get a nikimachi!!
Username: Spyder
Eglin AFB, Florida
Post Number: 211
hell if your gonna break the wallet....why not get a Zapco? very underated and will last long enought to pay for themselves twice over.
Username: Tjmutlow
Post Number: 393
find an old orion 275 amp. they run down to .5ohm....
Username: James1115
Wilton, Ct
Post Number: 4347
I agree with simon! Although Ty has a good idea also but good luck finding one in good shape. Isaac already cornered the market in those amps:-). If you had a dual 2 ohm I would have sold you my orion 250g4 but its not enough power at 2ohms. Zapco, arc audio, old soundstream refference 1000 or refference 500, old RF power 650 or power 1000, nakamichi is very very good as well, Harrison Labs, sinfoni(very pricey). There are many great companies out there but you really cant go wrong with those mentioned.
Post Number: 412
Ya i wanted to get the dual 2 ohm so i couls run it at 1 ohm. But, i got this baby brand new for 230(cant beat that). I have been looking around for old orion hcca amps for awhile(can't find one that will be good at 2 ohms.) Also, the old soundstream and zapco's. Thanks for the input guys.
Home > Message Board > Car Audio > Amplifiers > Archive through December 18, 2005 > Best match [ « Previous ] [ Next » ]
