Thread: Engine Sound on the speakers |
Bronze Member Username: Vaio
Post Number: 92 Registered: Dec-04
| Posted on Saturday, December 10, 2005 - 06:27 pm: |
I install a overhear dvd lcd with dvd its work but i have the sound of the engine on the speakers when driving. I install a FM Modulator for the dvd player to the stereo I hear the engine is there something worng that i did when i install it? THANKS |
Silver Member Username: Tjmutlow
Post Number: 310 Registered: Sep-05
| Posted on Saturday, December 10, 2005 - 06:54 pm: |
if the fm mod had ground, try unhooking it, rcas may be creating a ground loop, if that does not work, try ground loop isolator. |
Post Number: 93 Registered: Dec-04
| Posted on Saturday, December 10, 2005 - 07:34 pm: |
THANKS I WILL DO THAT THANKS |
