Thread: 96 Civic Dx stock alternator amps? |
New member Username: Chillyphil
Post Number: 2 Registered: Dec-05
| Posted on Thursday, December 08, 2005 - 09:27 pm: |
i have a stock 96 civic dx and am just wondering what size my alternator is. I will be putting in an Alpine mrv-f450 which is going to draw 400-500+ watts. i would consider buying a bigger alternator, but the amp really isnt that big so i am hesitant. i have a yellotop battery if it makes a difference in compensating for a small alternator. |
Silver Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 661 Registered: Feb-05
| Posted on Monday, December 12, 2005 - 07:54 pm: |
that amp pushes 200 watts RMS, thats like 16 amps of current draw, you should be fine if thats the only amp you are using in your system. your stock alternator is prob 70 amps, don't know for sure though. my 92 accord had a 70 amp alt in it. and the battery doesn't make up for the lack of a HO Alternator, but will be better then a stock one since its a deep cycle and can handle the charge/discharge better. |
Post Number: 10 Registered: Dec-05
| Posted on Tuesday, December 27, 2005 - 05:56 pm: |
acctually my amp pushes a bit more than 200 watts rms. it is 400watts rms, and being an alpine amp, its going to put out more than it is rated for unlike some other amps. |
Silver Member Username: Tjmutlow
Post Number: 702 Registered: Sep-05
| Posted on Tuesday, December 27, 2005 - 06:04 pm: |
that is the 5 channel and really is not a 4oo w rms amp,alpine is not underrated, it is max rated at 14.4 volts. |
