Thread: Alternator |
Bronze Member Username: Mwright1000
Post Number: 60 Registered: Dec-05
| Posted on Thursday, December 08, 2005 - 05:12 pm: |
I have 1994 gmc jimmy with a 100amp alternator in it. Do you think I will need a bigger one to run an Audiobaun A8002T and matbe a Audiobaun A4002T. Let me know what ya think. Thanks |
Gold Member Username: Carguy
Post Number: 5064 Registered: Nov-04
| Posted on Wednesday, December 14, 2005 - 11:43 am: |
Try it first. If you don't see any lights dimming, then it should be good. |
New member Username: Keegan_man
Post Number: 7 Registered: Oct-05
| Posted on Tuesday, December 20, 2005 - 01:54 pm: |
i have a 1990 toyota pick with a 90 amp alt. and i am goin to run 2 12" jl w3's with a 800 rms amp and a cap should i be ok? |
Silver Member Username: Redliner
Wilmington,
Ma
Post Number: 238 Registered: Jun-05
| Posted on Tuesday, December 20, 2005 - 04:35 pm: |
it should be pretty close ut the cap is just gonna add more strain to your alternator so you might want to think about it as a rule of thumb around 1000 watts you need a ho alt so its close for you it would be worth it to get one but you dont necassarliy need one |
