Thread: Does Cadence make good EQs? |
LessthanJake Unregistered guest |
| Posted on Thursday, December 01, 2005 - 11:05 pm: |
Hey can anyone tell me if Cadence makes good EQs? I got dis guy who wants to sell me his. Link--> http://www.cadencestore.com/ProductCart/pc/caraudio_detail.asp?idcategory=33&idp roduct=50 As far as i can tell its not parametric.I've never heard of paragraphic bfore..wat is dat? How does this compare to brands like Alpine,Kicker or AudioControl, etc. I've got an Alpine CDA-9831 for a HU and currently the builtin EQ is good enuff. I just tought having a separate EQ would be easier to adjust instead of goin into the HU menus and such. |
Silver Member Username: B101
Queen City,
NC
Post Number: 118 Registered: Sep-05
| Posted on Monday, December 05, 2005 - 11:58 am: |
if its a good price get it. how important is SQ mean to you? most budget EQ, xovers gets the job done. Unless you are competing for SQ or something |
LessNJake Unregistered guest |
| Posted on Thursday, December 15, 2005 - 08:31 pm: |
Thanks man. SQ is very important to me.. |
New member Username: Maxsq
Post Number: 6 Registered: Jul-06
| Posted on Friday, July 14, 2006 - 09:36 pm: |
I wouldn't spend my money on that. If you want SQ then stick with Audio Control!!! |
