Home > Message Board > Car Audio > Disc Changers > Archive through September 05, 2006 > JVC head unit problem
Author Thread: JVC head unit problem
Username: Reseaudio
Post Number: 17
I Have a JVC head unit that is a top of the line cd/mp3 player. Here is the deal. I could haved a brand new cd and when i play it for a while, even if i havent taken it out of the cd player to get scratched, the cd will skip and like the first song on most of my cds wont play? what could be happening? Could i need a new head unit?
Username: Glasswolf
NorthWest, Michigan
Post Number: 2347
laser pickup is out of alignment.
should be under warranty if the unit is pretty new.
Username: Reseaudio
Post Number: 18
if it isnt still under warranty then what can i do about this problem?
Username: Glasswolf
NorthWest, Michigan
Post Number: 2370
replace the unit
take the unit to a radio repair shop and pay
put up with the skipping
that's your list of options
Username: Reseaudio
Post Number: 19
ok.. thanks for the help again.
Username: Reseaudio
Post Number: 37
how complicated would it be to fix this problem myself?
manicgamer
hi i have an older jvc unit but i have a prob. the head unit works in my broco 2, but will not work in my tbird. the harnesses are the same but the radio will not turn on in the tbird. it did work but i was playing a cd and turned the bass up to +6 then it just shut off. i get no power to it but it works fine in my other car? what is wrong?????
j62493
i have a jvc headunit and does not play copied cd's only official ones it use to now it doesn't any one have a clue y, i tried differant cd's and differant burnign software to no avail
my head unit is 5 months old and when i put a cd in it doent reconise its there. the radio still works fine.
it happens with orginal cd not just cdrs.
I don't know a lot about changing car accessories. I did however, install an AM/FM radio in my Grandma's 85 Chevy that originally had only AM. That is the extent of my experience. I have a CD player and a tape player in my car. How easy and/or logical would it be to install a multi-disk player and keep my tape player?
Silvdafsdfa
HOw do I set the time on a JVC head unit? I bought an open box unit and got no instructions.
HEY MATE> did you find what was the problem?
i have this happening to my JVC HL2000
thanks
Username: Grizzly1579
Go to the JVC website. They have manuals for downloading
Home > Message Board > Car Audio > Disc Changers > Archive through September 05, 2006 > JVC head unit problem [ « Previous ] [ Next » ]
