Thread: How should i wire my amps and subs |
Bronze Member Username: Islandboy808
Mililani,
Hawaii
US
Post Number: 78 Registered: Nov-05
| Posted on Wednesday, November 23, 2005 - 12:54 am: |
Hi guys i was wondering how would i wire up my dvc 4 ohm alpine type S subwoofers.i currently have a hifonics brutus BX1500D(thanks chauncey). i want to hook it up the safest way as possible but with the most bang.I know the amp is way to powerful for those alpines so ill probly have to keep the gains down. |
Relevant Product Info
Silver Member Username: Bestmankind
Los Angeles,
CA
Post Number: 735 Registered: Oct-05
| Posted on Wednesday, November 23, 2005 - 01:13 am: |
i would connect them in series-parallel to a 4ohm load. i believe that amp is 500wrms at 4ohms. with a 1ohm load you would really over power them. |
Gold Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 1825 Registered: Jul-05
| Posted on Wednesday, November 23, 2005 - 01:44 am: |
ur welcome |
Mililani,
Hawaii
US
Post Number: 79 Registered: Nov-05
| Posted on Wednesday, November 23, 2005 - 03:46 am: |
ok another question my two subs are not hooked up together.they are in the same box but the back has to pairs of speaker input.one for each sub.how do i hook it up to 4 ohms.sorry for being such a noob.because it looks like the two subs are wired together and has 1 input on the back of the box. |
Mililani,
Hawaii
US
Post Number: 80 Registered: Nov-05
| Posted on Wednesday, November 23, 2005 - 03:50 am: |
when i go to this site it looks like its wired together
Mililani,
Hawaii
US
Post Number: 81 Registered: Nov-05
| Posted on Wednesday, November 23, 2005 - 03:53 am: |
its wired like this right now
each sub.no wires connected to each other.how many ohms is this anyway. |
Los Angeles,
CA
Post Number: 741 Registered: Oct-05
| Posted on Wednesday, November 23, 2005 - 10:26 am: |
just connect the subs like the first picture. aftere that take the positive from each sub and the negative from each sub and connect it to your amp. |
Mililani,
Hawaii
US
Post Number: 83 Registered: Nov-05
| Posted on Wednesday, November 23, 2005 - 10:52 pm: |
im lost lol.so only 1 of the in puts will be used? |
Mililani,
Hawaii
US
Post Number: 84 Registered: Nov-05
| Posted on Wednesday, November 23, 2005 - 10:53 pm: |
or should i say only one of the speaker terminals will be used.my box has two thats why |
Mililani,
Hawaii
US
Post Number: 85 Registered: Nov-05
| Posted on Wednesday, November 23, 2005 - 10:54 pm: |
two sets |
Gold Member Username: James1115
Wilton,
Ct
Post Number: 4269 Registered: Dec-04
| Posted on Wednesday, November 23, 2005 - 10:57 pm: |
yes only 1 will be used unless you do each sub seperate and then bridge it going into the amp take the 2 +'s and the 2 -'s and go to the amp its the same thing but you will use bot terminals. I would only do it this way if there is a divider in your box. |
Mililani,
Hawaii
US
Post Number: 86 Registered: Nov-05
| Posted on Thursday, November 24, 2005 - 12:12 am: |
yes it has a divider.so how should i wire them up. |
Mililani,
Hawaii
US
Post Number: 88 Registered: Nov-05
| Posted on Thursday, November 24, 2005 - 03:03 am: |
bump |
Los Angeles,
CA
Post Number: 772 Registered: Oct-05
| Posted on Thursday, November 24, 2005 - 09:01 am: |
if you have a divider then do as james said. do each sub separately and bridge it going in to the amp. |
