Home > Message Board > Car Audio > Security Systems > Archive through December 02, 2004 > Code Alarm
Author Thread: Code Alarm
Username: Piyaca
Everytime i try to start my car it does nothing. The battery is juiced and so is the code alram system. I reset the system to factory specifications and disconnected the battery and reconnected. Any ideas?
Something is hooked up wrong.
Username: Zacdavis~
Post Number: 92
if this is a remote start that your tryin to get to start i bet i know what wire you forgot to hookup, the parking brake wire, if it isn't grounded the system wont start.
Home > Message Board > Car Audio > Security Systems > Archive through December 02, 2004 > Code Alarm [ « Previous ] [ Next » ]
